Identify the profiles drilled in a frame for export step
BenjaCmoi
BenjaCmoi
I would like to create a rule Ilogic to export all the parts of a frame in step format on the fly in order to send my order for cutting. The problem I'm having is that I can't identify the drilled parts in my BOM. I can see that when I display the weight of my parts, it tells me that the value is variable. So for two parts of the same length but one drilled and the other not, I can't manage to split them in my BOM into two different parts. Do you have any ideas for separating them?
Thank you in advance
Andrii_Humeniuk
Hi @BenjaCmoi .
The BOM has the ability to combine rows of components if they have a common Part Number value. Accordingly, if these 2 (or more) components will have different other properties then they will be marked *Varies*.
A better way would be to have different designations for them in the Part Number property. In the following article, the ways to solve this issue are well described.
Good luck!
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
BenjaCmoi
Thanks Andrii... I'll take a look at it at the end of the day and come back to post a message if it corrects my problem. Have a great day
BenjaCmoi
My quantities are just right 🙂
