iAssembly and Excel Vba code
Hi to all -
I'm sorry for reposting this message.
Last couple days I was trying solve it myself
no lucks - please HELP:
I have a problem in simple code
after creation of assembly file
went to Creation of iAssembly and include/exclude
some parts.
Next step - edit iAssembly via spreadSheet
created two ComboBoxes on sheet2 (sheet1 for Inventor only)
All data on sheet3 - "Data"
Now main part - coding in excell:
Private Sub ComboBox1_Change()
Select Case Sheets("Data").Range("n30")
Case 0: ComboBox2.ListFillRange = "Digit_6"
Case 1: ComboBox2.ListFillRange = "Digit_6a"
Case 2: ComboBox2.ListFillRange = "Digit_6"
Case 3: ComboBox2.ListFillRange = "Digit_6a"
End Select
End Sub
to this point all works OK - Combo box 2 changing its
contents depend of choise in combobox 1.
Afrer saving & exiting Inventor opening the same file
generate an error - see attached pgn.
Please help me - thanks for any ideas
Ursus Uziemblo
Make sure you save and close the excel workbook after making changes in
Excel. The sequence should roughly be the following:
Dim oSheet As WorkSheet
Set oSheet = oFactory.ExcelWorkSheet
' Make changes in Excel sheet
oSheet.Cells(2, 1) = ....
oPartDoc.Update
Dim oWB As workbook
Set oWB = oSheet.Parent
oWB.Save
oWB.Close
oPartDoc.Save
oPartDoc.Close
Sanjay-
Thanks Sanjay,
I will try your idea - I let you know if its work
Ursus Uziemblo
ps
I'm creating assembly driven by Excel:
from seven pull_down menu user making selection
to create assembly # (A12.321.B).
After exiting assembly updates accordingly
uu
