I want to update values in a closed ipt, iam, and idw from an open idw
bmc_dowell
bmc_dowell
BASEDIRECTORY = "G:\Pipes\AUTOMATION FILES\"
BASEFILE = "10PIPE.ipt"
Dim UPDATEFILE As String = BASEDIRECTORY & BASEFILE
Dim pDoc As PartDocument = ThisApplication.?????
Dim pDoc.ComponentDefinition.Parameters.Item("DIAMETER").Value = DIAMETER 'PARAMETER IN IDW
This controller is setting parameters in around 10 of 200 parts and assemblies
then I plan to copy and rename the idws, parts, and assemblies to a new folder
(as well as dump the new assemblies into a new assembly)
I have done this from an assembly to parts in the assembly, but never to a closed assembly
Thanks for any help
bmc_dowell
Dim updateone As Inventor.PartDocument = ThisApplication.Documents.ItemByName(BASEDIRECTORY & BASEFILE) updateone.ComponentDefinition.Parameters.Item("DIAMETER").Value = DIAMETER
think this is the way but it isn't working yet
A.Acheson
You will need to open it but you can open it with visible set to false. Then update. The drawing will open the part in the background, so really opening it again will just move focus to that document.
Try This,
Dim updateone As Inventor.PartDocument =ThisApplication.Documents.Open(BASEDIRECTORY & BASEFILE,False)
updateone.Update
updateone.Save
Regards
Alan
bmc_dowell
Thanks so much I tried going down this road before but was missing ComponentDefinition
I had done it years ago just couldn't find it
bmc_dowell
Just in case someone gets here and it seems a smaller number
updateone.ComponentDefinition.Parameters.Item("DIAMETER").Expression = DIAMETER
updateone.Update
updateone.Save
