I want to run an iLogic script to open all my .idw's in a folder and export them as .pdf
drafting3QE6L
drafting3QE6L
I have found a script that will open all .ipt's one by one and export an image of the iso view to a set folder.
Source: https://forums.autodesk.com/t5/inventor-customization/batch-export-images/td-p/5370275
Thing is, I want to tweak the code such that instead of opening parts, I want it to open Drawings, and instead of exporting a picture, I want a pdf. Would this be possible, or is this a bigger rabbit hole than I expected?
Thank you for any help,
James
Chancellor.Kurre
You could look into the Inventor task scheduler and try to print to a PDF printer. Haven't dug into it much for that, but it should work.
WCrihfield
Hi @drafting3QE6L .  This definitely sounds doable with an iLogic rule, but once started the task of opening every drawing file in a directory and exporting them will likely take a long time, depending on the scope (how many).  Because of how long the task may take though, this type of job is probably better suited for an Addin, or as @Chancellor.Kurre  suggested, using the Inventor Task Scheduler and printing them to file using a PDF printer.  I have written similar rule's before that target all documents of a certain type within a directory, open them, do something to them (like 'inject' iProperties), then close them, but I haven't created one for that specific task yet.
Wesley Crihfield
(Not an Autodesk Employee)
drafting3QE6L
@WCrihfield The good news is that timeframe will not be an issue. We are changing systems at work and once the transition is done, any edits to drawings will be exported then and there as pdf. I found a different block of code that will execute an "export as pdf" command, so right now it is a matter of inserting the code in a way that works.
Curtis_Waguespack
Hi @drafting3QE6L
You could give this example a try.
I hope this helps.
Curtis
Imports System.IO
'Imports System.Windows.Forms
Sub main
	' Define folder browse dialog
	Dim Dialog = New FolderBrowserDialog()
	' Set options for folder browser dialog
	'set initial folder location
	Dialog.SelectedPath = "C:\Temp\"
	Dialog.ShowNewFolderButton = False
	Dialog.Description = "Choose the folder that contains the drawings..."
	' Show dialog box
	If DialogResult.OK = Dialog.ShowDialog() Then
		' User clicked 'ok' on dialog box - capture the export path
		oFolder = Dialog.SelectedPath & "\"
	Else
		' User clicked 'cancel' on dialog box - exit
		Return
	Dim oList As New ArrayList
	Dim oDir As New DirectoryInfo(oFolder)
	iCount = 0
	For Each oFile As IO.FileInfo In oDir.GetFiles("*idw", IO.SearchOption.TopDirectoryOnly)
		oList.Add(oFile.FullName)
		iCount = iCount + 1
	Next
	oRUSure = MessageBox.Show(iCount & " drawings found... This could take a while, are you sure you want to run this batch?", _
	"iLogic", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
	If oRUSure = vbNo Then
		Return 'exit rule
	oPDF_Folder = oFolder & "PDF Folder\"
	'Check for the PDF folder and create it if it does not exist
	If Not System.IO.Directory.Exists(oPDF_Folder) Then
		System.IO.Directory.CreateDirectory(oPDF_Folder)
	For Each oItem In oList
		oDoc = ThisApplication.Documents.Open(oItem, True)
		Call Export_PDF(oDoc, oPDF_Folder)
		oDoc.Close()
	Next
	MessageBox.Show("PDF export is complete.", "iLogic", MessageBoxButtons.OK, MessageBoxIcon.Information)
	ThisDoc.Launch(oPDF_Folder)
End Sub
Sub Export_PDF(oDoc As Document, oPDF_Folder As String)
	oName = IO.Path.GetFileNameWithoutExtension(oDoc.Fullfilename)
	oPDF = oPDF_Folder & oName & ".pdf"
	oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
	("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oDocument = ThisApplication.ActiveDocument
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
	'set PDF Options
	oOptions.Value("All_Color_AS_Black") = 1
	oOptions.Value("Remove_Line_Weights") = 1
	oOptions.Value("Vector_Resolution") = 400
	oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
	'Set the PDF target file name
	oDataMedium.FileName = oPDF
	Try
		'Publish document
		oPDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
	Catch
		Logger.Info("Error writing out PDF... " & oPDF)
	End Try
End Sub
drafting3QE6L
@Curtis_Waguespack It worked! Thank you for the help!
