I want to create a small window with title on part and sheet metal
cekol20
Message 1 of 16
cekol20
Hello everyone,
I have a question. Is it posibble to create line in part view for fill a title witout click on iproperties?
I want to see small field for write there title of parts.
Thanks for Your help!
Replies (15)
Message 2 of 16
CGBenner
Hello, and welcome.
I am having a hard time understanding what you would like to do.  Would you be able to share an image of what you are looking for?
Chris Benner
Message 3 of 16
EdvinTailwind
I understand this as you want to have easier access to the Title property? I don't think there is any standard solution, but plugins are available. We use iTools by Swedish company Cadcraft (now owned by NTI, I'm not sure how their current offering looks like), where we have a custom-built property-tab that looks like this:
Some values correspond to iProperties, and some are custom ones.
Message 4 of 16
CGBenner
@cekol20 Hello, do you still need help with this question?
Chris Benner
Message 5 of 16
Frederick_Law
You can use iLogic, macro or addin to make popup Window (dialog box).
Message 6 of 16
cekol20
Yes, still I need to help with this. I want to have easier access for titile of part. The number of part is assigned automatically but I need to fill a title of part. I dont want to lose a time for open iproperties in every parts. I want to create a strip seem like below. Is it posssible, If yes tell me how ;), thanks!
Message 7 of 16
CGBenner
@cekol20
From previous responses, it looks like what you are trying to do is possible through customization.  I am moving this post to the Inventor Programming forum.  Maybe someone in there can offer a solution, or help you find what you need.  Good luck.
Chris Benner
Message 8 of 16
AndrewHumiston
Good Afternoon,
Are you looking for something like this?
This is done by going to the Annotate tab and clicking General Note, select a screen quadrant i choose upper right:
Add some Text as a label in my example "Description:" then select the type of property you want to use under Type:
In my Example i use standard iproperites, then select the source, in an assembly i choose the primary model, or a part file would not have this selection:
Select which property you'd like to select:
then click the add parameter icon
then click ok, and you will have that text displaying what ever you like.
i hope this helps, please accept as a solution if this solves you question, if not lets get it figured out!
Message 9 of 16
cekol20
@AndrewHumiston
Exactly like this but also I need edit from main page a name of part.
Message 10 of 16
AndrewHumiston
to do that you would need to use a custom user form and some ilogic.
are you looking to edit these values?
Message 11 of 16
cekol20
@AndrewHumiston
Yes, I want to edit this from main page of creating part or sheet metal.
Message 12 of 16
AndrewHumiston
Are you asking for a from in the part file? or inside the *.idw?
Message 13 of 16
cekol20
I asked about edition from part page (.ipt).
Message 14 of 16
AndrewHumiston
You will need to create a user from in the ilogic window right click in the gray area and select Add Form:
Click iProperties on the top of the form:
Click and drag the properties to the right:
Ensure Modal is set to false, this allows you to work with inventor while this form is open:
Select ok to close the form editor
Select you new form by clicking in the forms tab:
Change your values :
i hope this helps, if this solves your issue, please accept solution to help others better find this answer.
thank you!
Message 15 of 16
cekol20
@AndrewHumiston
The window "Form 1" will be open all the time (automatically) when I will create or open a part and sheet metal?
Message 16 of 16
AndrewHumiston
i will caution you against this. you could very easily have alot of windows open that are related to files that are not the active file you are viewing.
you will need a rule to handle the opening of the form to trigger on open of a file and a similar rule to close the form when you are finished with that file.
once again i caution against this as you will have multiple files with different forms and you won't know which form is for which open file.
