i want to change part list width of all collumns in idw via vba
k14348
Message 1 of 10
k14348
  I have a idw file with 50 Nos. of sheets. Every sheet there is a part list which is ununiform. i want to edit the part list collumn width via vab. i already have revision table width program. i'm attaching that for your reference.
Sub Change_Revision_table_width()
Dim oDoc As Document
Dim oSheet As Sheet
Dim oRevisionTables As RevisionTable
Dim oRevisionTableColumn As RevisionTableColumn
Dim oColumnName As String
Dim oWidth As Double
Set oDoc = ThisApplication.ActiveDocument
If oDoc.DocumentType = kDrawingDocumentObject Then
    Set oSheet = oDoc.ActiveSheet
    oSheet.Activate
    For Each oRevisionTables In oSheet.RevisionTables
        For Each oRevisionTableColumn In oRevisionTables.RevisionTableColumns
        oColumnName = oRevisionTableColumn.Title
        If oColumnName = "Rev." Then ' <--- You Can change the column name in here to what ever column you need
            oRevWidth = ".8"
            oRevisionTableColumn.Width = oRevWidth
        If oColumnName = "Cpy Rev" Then ' <--- You Can change the column name in here to what ever column you need
            oCpyRevWidth = "1.2"
            oRevisionTableColumn.Width = oCpyRevWidth
        If oColumnName = "Status" Then ' <--- You Can change the column name in here to what ever column you need
            oStatusWidth = "1.8"
            oRevisionTableColumn.Width = oStatusWidth
        If oColumnName = "Rev. Date" Then ' <--- You Can change the column name in here to what ever column you need
            oRevDateWidth = "1.8"
            oRevisionTableColumn.Width = oRevDateWidth
        If oColumnName = "Revision Description" Then ' <--- You Can change the column name in here to what ever column you need
            oRevDesWidth = "4.4"
            oRevisionTableColumn.Width = oRevDesWidth
        If oColumnName = "Issued by" Then ' <--- You Can change the column name in here to what ever column you need
            oIssuedWidth = "2.0"
            oRevisionTableColumn.Width = oIssuedWidth
        If oColumnName = "Reviewed by" Then ' <--- You Can change the column name in here to what ever column you need
            oReviewedWidth = "2.0"
            oRevisionTableColumn.Width = oReviewedWidth
        If oColumnName = "Appr. ENG" Then ' <--- You Can change the column name in here to what ever column you need
            oApprWidth = "2.0"
            oRevisionTableColumn.Width = oApprWidth
        If oColumnName = "Appr. PMT/OPS" Then ' <--- You Can change the column name in here to what ever column you need
            oApprPMTWidth = "2.0"
            oRevisionTableColumn.Width = oApprPMTWidth
        If oColumnName = "Part. Accept." Then ' <--- You Can change the column name in here to what ever column you need
            oPartaccWidth = "2.0"
            oRevisionTableColumn.Width = oPartaccWidth
        Next
    Next
Else
    MsgBox "The Selected document is not a drawing document please select a drawing document and continue", vbOKOnly, "Edit Revision Table  Column Width:"
    Exit Sub
End Sub
Thank you,
karthikeyan M
+91-9894814348
Replies (9)
Message 2 of 10
Owner2229
Hi, first here is your RevisionTable rule simplified:
If oDoc.DocumentType <> kDrawingDocumentObject Then
    Exit Sub
Dim oSheet As Sheet
oSheet.Activate
Dim oRevisionTable As RevisionTable
For Each oRevisionTable In oSheet.RevisionTables
    Dim oColumn As RevisionTableColumn
    For Each oColumn In oRevisionTable.RevisionTableColumns
oColumnName = oColumn.Title
Select Case oColumnName Case "Rev.": oWidth = ".8" Case "Cpy Rev": oWidth = "1.2" Case "Status": oWidth = "1.8" Case "Rev. Date": oWidth = "1.8" Case "Revision Description": oWidth = "4.4" Case "Issued by": oWidth = "2.0" Case "Reviewed by": oWidth = "2.0" Case "Appr. ENG": oWidth = "2.0" Case "Appr. PMT/OPS": oWidth = "2.0" Case "Part. Accept.": oWidth = "2.0"
Case Else: Continue For
End Select oColumn.Width = oWidth Next oColumn Next oRevisionTable End Sub
Second, here is the rule for the part lists:
Sub Change_PartLists_Width()
    Exit Sub
Dim oSheet As Sheet
For Each oSheet In oDoc.Sheets
    oSheet.Activate
    Dim oPartList As PartList
    For Each oPartList In oSheet.PartLists
        Dim oColumn As PartsListColumn
        For Each oColumn In oPartList.PartsListColumns
' Specify your columns here, one row per column Select Case oColumnName Case "Rev.": oWidth = ".8" Case "Cpy Rev": oWidth = "1.2" Case "Status": oWidth = "1.8" Case "Rev. Date": oWidth = "1.8" Case "Revision Description": oWidth = "4.4" Case "Issued by": oWidth = "2.0" Case "Reviewed by": oWidth = "2.0" Case "Appr. ENG": oWidth = "2.0" Case "Appr. PMT/OPS": oWidth = "2.0" Case "Part. Accept.": oWidth = "2.0" Case Else: Continue For End Select oColumn.Width = oWidth Next oColumn Next oPartList Next oSheet End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 10
k14348
  Thanks for quick reply. It's showing some error. Error file attached in this mail.
-karthikeyan M
Whatsapp +91-9962356080
Message 4 of 10
Owner2229
Try to place this in front of the sub:
Imports Inventor
Sub ...
If it won't help, use this:
Inventor.PartList
Mike
Message 5 of 10
k14348
Sorry not working..
Message 6 of 10
Owner2229
Sorry, my mistake. It should be "PartsList" instead of "PartList".
Here's the corrected version:
    Exit Sub
Dim oSheet As Sheet
    oSheet.Activate
    Dim oPartsList As PartsList
    For Each oPartsList In oSheet.PartsLists
        For Each oColumn In oPartsList.PartsListColumns
            End Select
        Next oColumn
    Next oPartsList
Next oSheet
End Sub
Mike
Message 7 of 10
k14348
It's not working Error file attached.
Message 8 of 10
Owner2229
So, apparently VBA doesn't support "Continue For", so we have to do it another way:
    Exit Sub
Dim oSheet As Sheet
    oSheet.Activate
            Case "Rev.":                 oWidth = 0.8
            Case "Cpy Rev":              oWidth = 1.2
            Case "Status":               oWidth = 1.8
            Case "Rev. Date":            oWidth = 1.8
            Case "Revision Description": oWidth = 4.4
            Case "Issued by":            oWidth = 2
            Case "Reviewed by":          oWidth = 2
            Case "Appr. ENG":            oWidth = 2
            Case "Appr. PMT/OPS":        oWidth = 2
            Case "Part. Accept.":        oWidth = 2
            Case Else:                   oWidth = 0
            End Select
            If oWidth > 0 Then oColumn.Width = oWidth
        Next oColumn
    Next oPartsList
Next oSheet
End Sub
You can apply the same change for the revisited "Change_Revision_table_width" sub.
Mike
Message 9 of 10
k14348
   Its working thanks. Can i have ur mail id.
-karthikeyan M
whatsapp +91-9962356080
Message 10 of 10
Owner2229
You mean my email? Sure:
*MyForumNick*@gmail.com
Mike
