I want to center a dimension value above the dimension line
I have two planes located at both ends of a channel. This is because the total length may change based on input parameter. Also there may be some parts attached to the end of the channels which shouldn't come under measurement so I chose to use planes. In drawing file I already created a dimension between those two planes.
The issue is when I try to change the run length of the project the dimension line is still attached to the planes but the dimension value is sometimes coming out of the specified area or not in the middle.
I tried to center the dimension text but it didn't work. Also while tinkering this idw file in Inventor I found out that if I toggle the Leader option in Options choice On and then Off then somehow the value is centered. I am trying to implement that in ILogic but it is not working.
