I need to redirect the save path of a file
Miguel.CarvajalS34Q6
I am using a code to organize the name with which the inventor's .ipt file will be saved. but I would like to be able to select the location where it will be saved.
Thank you very much for the help.
this is the code used
'get model doc
oModleDoc = ThisDoc.ModelDocument
'process file name
'get  position of the last backslash
Dim FNamePos As Long
FNamePos = InStrRev(oModleDoc.FullFileName, "\", -1)
'get file name
Dim docFName As String
docFName = Right(oModleDoc.FullFileName, Len(oModleDoc.FullFileName) - FNamePos)
'define the property set
oDTPs = oModleDoc.PropertySets.Item("Design Tracking Properties")
oPN = oDTPs.Item("Part Number").Value
'replace old file name with iproperty value
oPathAndName = Replace(oModleDoc.FullFileName,docFName,oPN)
'save off a copy
ThisDoc.Document.SaveAs(oPathAndName & ".ipt" , True)
'present message to user
MessageBox.Show("File saved to: " & oPathAndName & ".ipt", "iLogic")
Andrii_Humeniuk
Hi @Miguel.CarvajalS34Q6 . Please review if this is what you wanted.
oDoc = ThisDoc.Document
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Inventor Files (*.ipt)|*.ipt|All Files (*.*)|*.*"
oFileDlg.FileName = oPathAndName & ".ipt"
oFileDlg.ShowSave()
If oFileDlg.FileName Is Nothing Or oFileDlg.FileName = "" Then Exit Sub
Dim sPath As String = System.IO.Path.GetDirectoryName(oFileDlg.FileName)
Dim sName As String = System.IO.Path.GetFileNameWithoutExtension(oFileDlg.FileName)
oDoc.SaveAs(sPath & "\" & sName & ".ipt", False)
Example execution of this code.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
unfortunately the code does not perform the expected task, thank you very much for the suggestion
