I need an External Rule to recursively change select part colors in an assembly
The Inventor API is incredible, but its flexibility also makes it difficult for me to learn.  After hours of working on this problem, I am crying for HELP!  🙂
I need an External Rule to recursively change select part colors in an assembly.
I have large assemblies with numerous sub-assemblies, three or four levels deep. The parts in the various assemblies are various colors and I want to be able to change those various colors (on the part level) with an external rule based on the individual part's starting color.
For instance, I may want to change the red parts to blue, but the green ones to yellow.
That means I need code that drills down to each part in each assembly, then assigns a new part color based on that part's current color.
This borrowed code more or less does what I want to do, but with the Material property instead of color:
Public Sub ChangeAllPartMaterial()
    ' Get the active assembly document.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    ' Get the material to assign to all of the parts.
    Dim strMaterialName As String
    Dim oMaterial As Material
    On Error Resume Next
    oMaterial = oAsmDoc.Materials.Item(strMaterialName)
    On Error Goto 0
    ' Iterate through all of the documents refrenced by the assembly.
    Dim oDoc As Document
    For Each oDoc In oAsmDoc.AllReferencedDocuments
        ' Check to see if this is a part.
        If oDoc.DocumentType = kPartDocumentObject Then
            Dim oPartDoc As PartDocument
            oPartDoc = oDoc
            ' Set the material.
''''' Here I would like to assign the color, instead of the material ''''
''''' The new color would be based on what the old color was. ''''
strMaterialName = "Gold" oPartDoc.ComponentDefinition.Material = oMaterial End If Next End Sub
Any help would be greatly appreciated!
- Ron
Is color part of the ComponentDefinition object?
Anyone want to take a stab at this question?
