Message 1 of 1
I-Logic to generate SAT files in Sheetmetal Assembly
Hi, I have the below codes to create .SAT files in sheet metal assembly.
Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4) RUsure = MessageBox.Show( _ "This Rule is to create SAT files from sheet metal" _ & vbLf & "Be sure you have made the correct sheetmetal rule and flatterned" _ & vbLf & " " _ & vbLf & "This could take a while.", "iLogic - CONVERT SHEET METAL TO SAT's",MessageBoxButtons.YesNo) If RUsure = vbNo Then Return Else End If Dim oFN As String Logger.Info("Filename :" & oFN) oPath = ThisDoc.Path 'get SAT target folder path oFolder = oPath & "\" & oAsmName & " .SAT Files" 'Check for the SAT folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If Dim oSMCD As Inventor.SheetMetalComponentDefinition For Each oDoc In ThisApplication.ActiveDocument.AllReferencedDocuments If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then oSMCD = oDoc.ComponentDefinition 'If oSMCD.FlatPattern Is Nothing Then 'oSMCD.Unfold 'Else 'oSMCD.FlatPattern.Edit 'End If oFN = Left(oDoc.FullFileName, Len(oDoc.FullFileName) -4) & ".sat" 'Logger.Info("Filename :" & oFN) oDoc.SaveAs(oFN , True) 'oSMCD.FlatPattern.ExitEdit 'oDoc.Close End If Next
Here is the result:
What I request:
1. Since the result of SAT's stays outside of the folder, I want the sat files to stay in the folder.
2. Change every dot file name on IPT parts to dash (-) after converting to SAT.
Example: Test.one.JP.ipt become Test-one-JP.sat
Appreciated your help
