I logic rule in sub assembly wont trigger with I properties because true false?
t_fransman
Message 1 of 41
t_fransman
I need an identical rule forced to run in a sub assembly when true or false is changed in the form. I have to go to the sub-assembly and run the rule it's annoying. Node is Named "BottomWeldment". Rule runs in the top level assembly but not "BottomWeldment". The rule has same name and basically does same thing, turns stuff on vis and ref or default. Just can't seem to trigger it from top level. Rule name is "Door Hand".
Replies (40)
Message 41 of 41
t_fransman
A million thanks. I can't believe that was the difference between them
oPane1 = ThisDoc.Document.BrowserPanes("Model") works
oPane1 = ThisApplication.ActiveDocument.BrowserPanes("Model") epic fail
So greatful for your help . So tricky, but it's worth it. And if you know, you know.
