I-logic code for automatically creating DXF files and save in the destination folder.
AkshayM9WQXB
AkshayM9WQXB
Hi, I'm new to to I-logic and couldn't figure out how to work with the codes I found on this forum to convert my sheet metal kitchen equipment assembly to generate DXF files automatically with just a few clicks. Can anyone provide the code which will work for Inventor 2024?
A.Acheson
Hi @AkshayM9WQXB
If you have a sample code you started working with and couldn't figure it out then post it here and user can help you trouble shoot. I would always start with getting a dxf from one part then figure out how to run through the assembly and target all parts. Did you get one that gives a satisfactory result for the parts you want?
Regards
Alan
TylerWarner33
There are other posts, like these recent ones, on how to export a DXF.
Error Exporting to DXF
DXF iLogic Rule for creating DXF
As mentioned above, try working with these & others. Let us know if you get stuck by providing code samples of what you've tried.
If this answered your question, click 'Accept Solution'.
If this was helpful, click 'Like'.
Tyler Warner
GosponZ
Here is code which works perfect. Make as external rule.
