i = GoExcel.FindRow
i = GoExcel.FindRow
AMN3161
i = GoExcel.FindRow
AMN3161
I know this probably isn't the cleanest way to do this but i am very novice to ilogic and i at least understand what's going on
Dim partNumber As String = iProperties.Value("Project", "Part Number")
partNumber = partNumber.Trim().ToUpper()
i = GoExcel.FindRow("P:\_MASTER_PART_LIST\MASTER_PART_LIST.xls", "MASTER_PART_LIST", "Part No.", "=", partNumber)
If i <> -1
	iProperties.Value("Project", "Description") = GoExcel.CurrentRowValue("Description")
	iProperties.Value("Project", "Vendor") = GoExcel.CurrentRowValue("Manufacturer")
	Dim partDescription As String = iProperties.Value("Project", "Description")
	partDescription = partDescription.ToUpper()
	iProperties.Value("Project", "Description")= partDescription
	Dim partVendor As String = iProperties.Value("Project", "Vendor")
	partVendor = partVendor.ToUpper()
	iProperties.Value("Project", "Vendor")= partVendor
Else
iProperties.Value("Project", "Description") = "The entered Part Number does not exist in the Master Parts List"
iProperties.Value("Project", "Vendor") = "The entered Part Number does not exist in the Master Parts List"
I am going to be adding more If statements for different scenarios, right now the else is there if the part number is not found in the excel look up. what is this function called " i <> -1"? didn't find much trying to google it. I am looking to hopefully use the "i" instead of a else statement because i am going to have a few if statements that would include if the look up cant find the part number.
This is my work in progress
  Dim oDoc As Document
oDoc = ThisDoc.Document
'define list of custom properties to delete
Dim MyArrayList As New ArrayList
MyArrayList.Add("Part_Number_1")
MyArrayList.Add("Part_Number_2")
MyArrayList.Add("Part_Number_3")
MyArrayList.Add("Part_Number_4")
MyArrayList.Add("Part_Number_5")
'define custom property collection
oCustomPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
'[ Adds custom properties
For Each oItem In MyArrayList
	oFlag = False 'set flag to default value
	'look at each property in the collection
	For Each oCustProp In oCustomPropertySet
		'check property name against the list item
		If oItem = oCustProp.Name Then
			oFlag = True 'trip the flag
	Next
	If oFlag = False Then
		'Create new iProperty
		iProperties.Value(oDoc, "Custom", oItem ) = ""
Next
'[ Erases custom properties
		If oCustProp.Name = oItem Then
	Next
		'delete property
		oCustProp.Delete
Next
'[ If 1-5 are Blank and a Part Number is Found
If iProperties.Value("Custom", "Part_Number_1") = "" And iProperties.Value("Custom", "Part_Number_2") = "" And iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = "" And i <> -1
	iProperties.Value("Project", "Vendor") = partVendor
'[ If 2-5 are Blank and a Part Number is Found
Else If iProperties.Value("Custom", "Part_Number_2") = "" And iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = "" And i <> -1
	Dim partNumber1 As String = iProperties.Value("Custom", "Part_Number_1")
	partNumber1 = partNumber1.Trim().ToUpper()
	i = GoExcel.FindRow("P:\_MASTER_PART_LIST\MASTER_PART_LIST.xls", "MASTER_PART_LIST", "Part No.", "=", partNumber1)
	Dim partDescription1 As String = iProperties.Value("Project", "Description")
	partDescription1 = partDescription1.ToUpper()
	iProperties.Value("Project", "Description")= partDescription1
	Dim partVendor1 As String = iProperties.Value("Project", "Vendor")
	partVendor1 = partVendor1.ToUpper()
	iProperties.Value("Project", "Vendor") = partVendor1
	iProperties.Value("Project", "Part Number") = partNumber1
 I would want that if Part Number 3-5 are blank them take Part number 1 and 2 then combine them into one line to replace the Part Number in the properties. Then take those two part numbers and combine the descriptions and manufacturers into their own lines respectively. So I don't think I can just use a else statement if the look up cant find the part number in the excel but what if it cant find Part Number 1 or Part Number 2? It would require two else statements which I am not able to do.
I understand how to combine the two the text into a line, its just the different scenarios where a part number is not found
Like what if I have two if statements where Part number 1 is found but Part Number 2 isn't and vice versa, so a else statement would work because 2 of those would be separate If statements and a all encompassing Else statement wouldn't work
Any recommendations of what I can do here, and I hope it explained it properly.
WCrihfield
- One thing you could do is create multiple simple boolean type variables before the search, with each one named specifically for one of the things you are going to be searching for.  During search, if item is found, set its boolean to True.  After search, check values of those boolean variables, to determine which of many actions you want to take as a result.
- Also the Try...Catch...End Try block of code can become more dynamic than the simple examples you usually see.  It can have multiple Catch statements, and can also have a Finally statement.  Perhaps you could make use of this behavior.
- Or just create more levels to your If...Then statements, to include more checks.  For example, if it finds one of multiple target items, you could use a Then, then on the next line, start another If...Then layer that searches for the second target item (could even use another loop if needed) below that If...Then, to dig deeper.
Wesley Crihfield
(Not an Autodesk Employee)
AMN3161
cant delete a reply so i just edited, let me try that
AMN3161
How would i do the boolean portion of your reply?
I saw how to implment the try portion of your reply which works and does its job but i am struggling with the catch
If i <> -1
	Try
	Exit Try
Catch
End Try
WCrihfield
I may have misunderstood which code you were talking about when I suggested the multiple booleans strategy.  I was thinking about alternatives to the much longer code within your first post.
Here's the Try...Catch version of that last (shorter) code you posted.
If i <> -1
	'So now we know it found the value of "partNumber" in the Excel file,
	'but we (I) technically still don't know if the cells within the "Description" and/or "Manufacturer" columns of the found row contain anything
	'and this is why we're (I'm) still cautious
	'If both cells will always be filled in, you can delete the Try...Catch blocks and delete the alternative actions (just leave the code used in the Try portion)
	Dim oDesc As String
	Try
		'if it does find a value, we've just defined it as a String
		oDesc = GoExcel.CurrentRowValue("Description")
		'If that worked, this should also work without any errors
		iProperties.Value("Project", "Description") = oDesc.ToUpper
	Catch 'what to do if the Try portion fails (doesn't find a value in that cell)
	End Try
	Dim oVendor As String
	Try
		oVendor = GoExcel.CurrentRowValue("Manufacturer")
		iProperties.Value("Project", "Vendor") = oVendor.ToUpper
	Catch
	End Try
Else
 And here is the purely If...Then...ElseIf...Else...End If version of that code.
If iProperties.Value("Project", "Part Number") <> vbNullString Then
	partNumber = iProperties.Value("Project", "Part Number")
Else
	MsgBox("The 'Part Number' property is blank. Exiting.", vbOKOnly, " ")
	Exit Sub
If i = -1 Then
	MsgBox("That Part Number wasn't found within the Excel file. Exiting.", vbOKOnly, " ")
	Exit Sub
Else
	Dim oDesc As String
	If GoExcel.CurrentRowValue("Description") IsNot Nothing Then
	Else 'it was Nothing (no value found in that cell)
	If GoExcel.CurrentRowValue("Manufacturer") IsNot Nothing Then
	Else
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
Wesley Crihfield
AMN3161
this is extremely helpful thank you!
AMN3161
I had to tweak it because some poor communication on my part but this is how it looks
	Next
Next
	Next
		'delete property
		oCustProp.Delete
Next
'[ Part Number and 1-5 Blank
If i = -1 And iProperties.Value("Custom", "Part_Number_1") = "" And iProperties.Value("Custom", "Part_Number_2") = "" And iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = ""  Then
	Exit Sub
Else
	Dim oDesc As String
'[ 2-5 Blank
	partNumber1 = iProperties.Value("Custom", "Part_Number_1")
If i = -1 And iProperties.Value("Custom", "Part_Number_2") = "" And iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = ""  Then
	Exit Sub
Else
	Dim oDesc1 As String
		oDesc1 = GoExcel.CurrentRowValue("Description")
		iProperties.Value("Project", "Description") = oDesc1.ToUpper
		iProperties.Value("Project", "Part Number") = iProperties.Value("Custom", "Part_Number_1")
	Dim oVendor1 As String
		oVendor1 = GoExcel.CurrentRowValue("Manufacturer")
		iProperties.Value("Project", "Vendor") = oVendor1.ToUpper
 But your code gave me the idea of what i wanted done, thank you!
