HSM-API from Standalone-EXE: Library not registered
astuy
astuy
With the following snippet I'm trying to access HSM API:
#region only in Standalone-EXE
var invAppType = Type.GetTypeFromProgID("Inventor.Application");
var invApplication = (Application)Activator.CreateInstance(invAppType);
invApplication.Documents.Open("Path\\to\\HSM-Part.ipt");
#endregion
// the following works inside Inventor-Addin, but not in Standalone EXE
var hsmAddin = invApplication.ApplicationAddIns.ItemById["{749E667C-2560-416A-A5E7-68B96FF997B1}"];
var hsmApi = (InventorHSMAddinAPI)hsmAddin.Automation;
As the snippet says: the last two lines work as expected in an Inventor-Addin. But running this from a Standalone-EXE, I get an Exception:
Library not registered. (Exception of HRESULT: 0x8002801D (TYPE_E_LIBNOTREGISTERED))
Is there missing a dll? Or what's the problem?
  • HSM
yan.gauthier
to access Inventor object from outside, use Marshal:
 public static void Main()
            Application InvApp;
            try
                InvApp = (Inventor.Application)Marshal.GetActiveObject("Inventor.Application");
            catch
                MessageBox.Show(new Form() { TopMost = true }, "Unable to get Inventor, Please launch the application.");
                return;
            // Here the fun begins
            //Prepare variables
astuy
Did you try to get the HSM-API? On my end the exception is still there...
Furthermore, I necessarily need a new Inventor-Instance and your way only works with a running Inventor instance.
