HowTo: Add a ButtonPopup to Inventor GUI?
I want expand the GUI from a Ribbon with one Button (see below) to a ribbon
with a ButtonPopup for two Buttons. Has someone an example or can expand my
code below? Environment: Inventor 2010 AddIn, with VB.Net 2005, 32 Bit
Many thanks in advance.
doc snyder
Private Sub AddExportButton(ByVal bFirstTime As Boolean)
' Create the button definition.
Dim controlDefs As ControlDefinitions
controlDefs = m_InvApp.CommandManager.ControlDefinitions
' Convert the Image to a Picture.
Dim picSmall As stdole.IPictureDisp, picBig As stdole.IPictureDisp
picSmall =
Microsoft.VisualBasic.Compatibility.VB6.ImageToIPictureDisp(My.Resources.Pic_Export_Small)
picBig =
Microsoft.VisualBasic.Compatibility.VB6.ImageToIPictureDisp(My.Resources.Pic_Export_Big)
m_oButtonDef = controlDefs.AddButtonDefinition( _
"Measure Program Generator", _
"ExportMeasureAddIn", _
CommandTypesEnum.kQueryOnlyCmdType, _
m_ClientID, _
Measure Program Export", _
picSmall, picBig)
If bFirstTime Then
' Create a new command bar (toolbar) and make it visible.
Dim commandBars As CommandBars
commandBars = m_InvApp.UserInterfaceManager.CommandBars
Dim commandBar As CommandBar
commandBar = commandBars.Add("Measure Program", "ExportMeasureAddIn",
, m_ClientID)
commandBar.Visible = True
' Add the control to the command bar.
commandBar.Controls.AddButton(m_oButtonDef)
End Sub
Ralf_Krieg
Hello
Simplified, create a second CommandBar of Type SplitButton. Add your first button to the SplitButton and then add the SplitButton to your CommandBar. Edited by: krieg on Feb 26, 2010 5:41 PM
R. Krieg
RKW Solutions
www.rkw-solutions.com
Ralf_Krieg
Could not test it, but try this.
picSmall =
picBig =
m_ClientID, _
picSmall, picBig)
If bFirstTime Then
, m_ClientID)
'Create a command bar of a splitbutton type for a flyout.
Dim oSplitBtnCmdBar As CommandBar
Set oSplitBtnCmdBar = objInventorApp.UserInterfaceManager.CommandBars.Add("SplitButtonname", "ExportMeasureAddIn", kSplitButtonMRUCommandBar, m_ClientID)
' Add two buttons to the splitbutton command bar.
oSplitBtnCmdBar.Controls.AddButton m_oButtonDef
' add splitbutton to commandbar
Call oCommandBarSlot.Controls.AddSplitButtonMRU(oSplitBtnCmdBar, "SplitButtonname")
End Sub Edited by: krieg on Feb 26, 2010 3:42 PM
R. Krieg
RKW Solutions
Hello krieg,
thank you for the example. I instead have used a workaround by inserting two
simple buttons. Your given example fails, se below. In addition, I've tried
to use the AddButtonPopup function, which fails also. Nothing to do! The
user accepts the simple solution.
doc snyder
I get a exception at line
oSplitBtnCmdBar =
m_InvApp.UserInterfaceManager.CommandBars.Add("SplitButtonname",
"ExportMeasureAddIn", _' CommandBarTypeEnum.kSplitButtonMRUCommandBar,
m_ClientID)
"System.Runtime.InteropServices.COMException (0x80004005): Unbekannter
Fehler (Ausnahme von HRESULT: 0x80004005 (E_FAIL))
bei System.RuntimeType.ForwardCallToInvokeMember(String memberName,
BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData&
msgData)
bei Inventor.CommandBars.Add(String DisplayName, String InternalName,
CommandBarTypeEnum CommandBarType, Object ClientId)
bei ExportMeasureAddin.CMeasureExporter.AddExportButtonsAsPopup(Boolean
bfirstTime) in
A try with following code fails also:
CommandBarTypeEnum.kButtonPopupCommandBar, m_ClientID)
m_oCmdBarCtrl = oCmdBarCtrls.AddButtonPopup(commandBar, m_oButtonDef)
m_obuttonCtl = oCmdBarCtrls.AddButton(m_oButtonDef)
m_oBtnParamCtl = oCmdBarCtrls.AddButton(m_oBtnParamDlgDef)
schrieb im Newsbeitrag news:6345000@discussion.autodesk.com...
Hello
