how two addins share one Tab?
Message 1 of 1
hi,
I have two addins (MyOne.dll & MyTwo.dll) and want them under one Tab (MyAddIn) in Part enviorment.
Each can creates the Tab by themself, but if two loaded together, how do they share that Tab.
I tried these code below:
            If (firstTime) Then
                Dim UIManager As UserInterfaceManager = m_inventorApplication.UserInterfaceManager
                If (UIManager.InterfaceStyle = InterfaceStyleEnum.kRibbonInterface) Then
                    Dim partRibbon As Inventor.Ribbon = UIManager.Ribbons.Item("Part")
                    Dim MyTab As RibbonTab = Nothing
                    For Each tab As RibbonTab In partRibbon.RibbonTabs
                        If tab.Name = "MyAddIn" Then
                            MyTab = tab
                            Exit For
                    Next
                    If MyTab Is Nothing Then
                        MyTab = partRibbon.RibbonTabs.Add("MyAddIn", "id_TabMyAddIn", MyOnestrAddInGuid)
                    Dim MyOnePanel1 As Inventor.RibbonPanel = MyTab.RibbonPanels.Add("MyOne", "MyOne:Panel1", MyOnestrAddInGuid)
                    MyPanel.CommandControls.AddButton(mPartButtonDef, True)
 Just wodering how do I deal with the strAddInGuid? Do I need to keep them all the same and even the same namespace?
Thx in advance
cean
Replies (0)
