How to write number of custom iProperties for all opened drawings to a list?
fabimann
fabimann
I'm trying to set up an external iLogic rule to export the file name and the number of custom iProperties for all opened drawings to a file. The result should look something like this:
NAME - NUMBER OF CUSTOM IPROPERTIES
file name 1.idw - 24
file name 2.idw - 7
Every hint is highly appreciated.
Best regards
Fabian
A.Acheson
What you will need is to access the documents object and look for visible documents collection. Loop through this collection and then check the document type against an  object type enumerator, you will find drawing "kDrawingDocumentObject" in that list. Then access the document object and look for fullfilename. Then access iproperties collection known as property sets then the custom iproperty property set known as "Inventor User Defined Properties" . Then retrieve the count per document of this custom iproperty.
Links for code creation from API help:
Documents object
Document Type
Object Type Enumerator
Document Object
Custom iProperty Sample
Property Set Count
Dim sList As New ArrayList
Dim opendoc As Document
For Each opendoc In ThisApplication.Documents.VisibleDocuments
	If opendoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject  Then
	 	' Get the user defined (custom) property set.
	    Dim invCustomPropertySet As PropertySet
	    invCustomPropertySet = opendoc.PropertySets.Item("Inventor User Defined Properties")
		sList.Add(opendoc.FullDocumentName & " - " & invCustomPropertySet.Count)' add to arraylist
Next
Item = InputListBox("Prompt", sList,Item, Title := "Drawing List", ListName := "List")
Regards
Alan
fabimann
Good morning,
it works perfectly thanks a lot for the code and the additional informations.
Best regards
Fabian
