How to verify if part is derived
I need to check if a part is derived because I'm developing a method to fix missing references.
To verify, I use a foreach that traverses all occurrences.
AssemblyDocument asmDoc = (AssemblyDocument)invApp.ActiveDocument;
ComponentOccurrences Occurrences = asmDoc.ComponentDefinition.Occurrences;
foreach (ComponentOccurrence oOcc in Occurrences)
In this example, it is possible to see that the reference is lost for the part that originated the derive.
I'm trying to do that, but I can not do it.
PartDocument oPart = (PartDocument)oOcc;
ReferenceComponents oRefsComps = oPart.ComponentDefinition.ReferenceComponents;
DerivedPartComponent oDerPartC = oRefsComps.DerivedPartComponents[1];
DerivedPartDefinition oDerPartDef = oDerPartC.Definition;
if (oDerPartDef is DerivedPartDefinition) {
    MessageBox.Show("yes");
Thanks.
sajith_subramanian
Autodesk Support
Autodesk Support
Hi marcelo.zattera,
To check for missing references you could try using the methods listed below.
1. To check if the reference is missing:
PartDocument.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1).ReferencedDocumentDescriptor.ReferenceMissing
2. To check if the component is suppressed:
PartDocument.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1).SuppressLinkToFile
3. To check if the component link is broken:
PartDocument.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1).LinkedToFile
Let me know if this helps.
Sajith
Sajith Subramanian
Autodesk Developer Network
