How to use MirrorFeatures.add to create Multi-body
Hi ,all
I need help,thanks
I have the following code,but it creates feature ,not multi-body
<code>
Public Sub Mirror()
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
' Set a reference to the component definition.
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
' Create a new sketch on the X-Y work plane.
Dim oSketch As PlanarSketch
Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
' Set a reference to the transient geometry object.
Dim oTransGeom As TransientGeometry
Set oTransGeom = ThisApplication.TransientGeometry
' Draw a rectangle
Dim oRectangleLines As SketchEntitiesEnumerator
Set oRectangleLines = oSketch.SketchLines.AddAsTwoPointRectangle( _
oTransGeom.CreatePoint2d(-1, 0), _
oTransGeom.CreatePoint2d(-4, -3))
' Create a profile.
Dim oProfile As Profile
Set oProfile = oSketch.Profiles.AddForSolid
' Create a base extrusion 1cm thick.
Dim oExtrude As ExtrudeFeature
Set oExtrude = oCompDef.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, 1, kNegativeExtentDirection, kJoinOperation)
Dim oParentFeatures As ObjectCollection
Set oParentFeatures = ThisApplication.TransientObjects.CreateObjectCollection
oParentFeatures.Add oExtrude
Dim oYZPlane As WorkPlane
Set oYZPlane = oCompDef.WorkPlanes.Item(1)
Dim oMirror As MirrorFeature
Set oMirror = oCompDef.Features.MirrorFeatures.Add(oParentFeatures, oYZPlane)
End Sub
<code end>
YuhanZhang
Modified the code as below:
Public Sub Mirror()
' Draw a rectangle
' Create a profile.
' Add the surface body as the mirror component
oParentFeatures.Add oPartDoc.ComponentDefinition.SurfaceBodies(1)
oMirror.NewBodyOperation = True
End Sub
Note: You should be able to mirror a surface body as a new body only, mirror a part feature does not support this.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Thanks a lot . It works well.
