How to use Logger inside a class?
j.pavlicek
j.pavlicek
Consider code:
Class ThisRule
Sub Main
    Dim x As new CustomClass
    x.Log("abc")
End Sub
End Class
Class CustomClass
    Public Sub Log(byval Value as String)
        Logger.Debug(Value) 'Line 10
    End Sub
End Class
Throws error:
Error on Line 10 : Logger is not declared. It may be inaccessible due to its protection level (this is translation from non-english system)
How to use Logger inside a class. What is Logger member of? (I tried Inventor.Logger, iLogic.Logger without succes.)
Inventor 2022, Windows 10 Pro
Sorry for bad English.
Accepted solutions (3)
JelteDeJong
It looks like you lose the normal logger as soon as you add a custom class to your rule. But you can still access the LogControl object. This object you can pass to your custom class through the constructor. That would look something like this.
Public Class ThisRule
	Public Sub Main()
		Dim logControl As LogControl =  iLogicVb.Automation.LogControl
		logControl.Log(LogLevel.Debug, "HelloWorld from ThisRule")
	    Dim x As New CustomClass(logControl)
	    x.Log("HelloWorld from CustomClass")
	End Sub
End Class
Class CustomClass
	Private _logControl As LogControl
	Public Sub New(logger As LogControl)
		_logControl = logger
	End Sub
    Public Sub Log(ByVal Value As String)
        _logControl.Log(LogLevel.Debug,Value)
    End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
Michael.Navara
I found similar solution. Logger is automaticaly generated property of ThisRule during compile time. You can use it in sub class, but you need to send reference to it.
I don't know if this is bug or feature, but when you use argument name "logger" the property Logger is not generated. See this example
Sub Main
	Logger.Debug("main")
	Dim oSubClass As New SubClass(Logger)
	oSubClass.TestLog("test")
End Sub
Class SubClass
	Private log As IRuleLogger
''   Uncomment this constructor raises a compile error at line 2
'	Public Sub New(logger As IRuleLogger, b As Boolean)
'		Me.log = logger
'	End Sub
	Public Sub New(log As IRuleLogger)
		Me.log = log
	End Sub
	Public Sub TestLog(msg As String)
		log.Info(msg)
	End Sub
End Class
C_Haines_ENG
I know its an old thread but I figured id add to it.
Sub Main
    CustomClass.iLog = Logger
    x.Log("abc")
End Sub
Class CustomClass
    Public Shared iLog as iRuleLogger
        iLog.Debug(Value) 'Line 10
    End Sub
End Class
