How to use DLL's from VB.net in VBA 7.0 (Inventor 2014)
christoph_stumpf
christoph_stumpf
I would use dll routines which are placed in an dll i have generated in VB.dot Net (Express Version 2010).
But when i will Reference the dll VBA of Inventor 2014 told it isn't possible.
Who can help me
ekinsb
I haven't tried it myself, but it should be possible.  Here are some instructions on creating a .Net class that will support COM.  http://support.microsoft.com/kb/817248  It will be more difficult to do using the Express edition since there are some tools missing for creating COM classes.  It's still probably possible but would be good to have a standard edition to be able to see what code it creates so you know what you have to duplicate manually.
Brian Ekins
Mod the Machine blog
Another option is to creae an inventor addin and expose your class in the "Automation" section.
Essentially the addin is a COM dll created in VB.NET so I do not know if you are gaining anthing by using it for this purpose.  Actually you are losing... as the addin is only accessable as type object.  No intellisense.
