How to use API to check Inventor instance "run as administrator"?
liminma8458
liminma8458
I understand Inventor has to be "Run as administrator" to make all the Addins work well. But sometimes the user indeed open Inventor without administrator right.
So how to use code (in VB.NET) to detect whether the current Inventor is "run as administrator" or not?
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
Curtis_Waguespack
Hi @liminma8458
Imports System.Security.Principal
Dim identity = WindowsIdentity.GetCurrent()
Dim principal = new WindowsPrincipal(identity)
Dim isElevated as Boolean = principal.IsInRole(WindowsBuiltInRole.Administrator)
If isElevated Then
  MessageBox.Show("Is Admin")
Else
  MessageBox.Show("Is NOT Admin")
See this link:
admin - How to check if application is running as administrator VB.NET - Stack Overflow
I hope this helps.
Curtis
liminma8458
Curtis,
Thank you so much. I wonder why I missed the Stack Overflow.
^_^
Limin
