How to use Addlinear with Thisdrawing.beginmange()
andreas.jonssonF98YC
Hi @JelteDeJong can you help me to convert a code that you wrote for overall dimensions
http://www.hjalte.nl/37-auto-overall-dimension so it works with Thisdrawing.beginmange()
i tried to convert it according to http://hjalte.nl/24-ilogic-adds-dimensions-to-drawings but I failed
Private Sub createHorizontalOuterDimension()
        Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.X)
        Dim pointLeft = orderedIntents.First
        Dim pointRight = orderedIntents.Last
        Dim textX = pointLeft.PointOnSheet.X +
                (pointRight.PointOnSheet.X - pointLeft.PointOnSheet.X) / 2
        Dim textY = _view.Position.Y - _view.Height / 2 - 2
        Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY)
        _sheet.DrawingDimensions.GeneralDimensions.AddLinear(
            pointText, pointLeft, pointRight, DimensionTypeEnum.kHorizontalDimensionType)
    End Sub
    Private Sub createVerticalOuterDimension()
    Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y)
    Dim pointLeft = orderedIntents.Last
    Dim pointRight = orderedIntents.First
    Dim textY = pointLeft.PointOnSheet.Y +
            (pointRight.PointOnSheet.Y - pointLeft.PointOnSheet.Y) / 2
    Dim textX = _view.Position.X + _view.Width / 2 + 2
            pointText, pointLeft, pointRight, DimensionTypeEnum.kVerticalDimensionType)
End Sub
JelteDeJong
Try it like this:
Public Class ThisRule
    Private _doc As DrawingDocument
    Private _sheet As Sheet
    Private _view As DrawingView
    Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
	Private _generalDimensions As IManagedGeneralDimensions
	Private _managedView As IManagedDrawingView
    Sub Main()
        _doc = ThisDoc.Document
        _sheet = _doc.ActiveSheet
        _view = ThisApplication.CommandManager.Pick(
                       SelectionFilterEnum.kDrawingViewFilter,
                       "Select a drawing view")
		_managedView = ThisDrawing.ActiveSheet.View(_view.Name)
		_generalDimensions = ThisDrawing.ActiveSheet.DrawingDimensions.GeneralDimensions
        CreateIntentList()
		ThisDrawing.BeginManage()
		ThisDrawing.EndManage()
    End Sub
		_generalDimensions.AddLinear(_view.Name & "Horizontal", _managedView.SheetPoint(0, 1.1),
			pointLeft, pointRight, dimensionType := DimensionTypeEnum.kHorizontalDimensionType)
    End Sub
		_generalDimensions.AddLinear(_view.Name & "Vertical", _managedView.SheetPoint(-0.1, 0),
			pointLeft, pointRight, dimensionType := DimensionTypeEnum.kVerticalDimensionType)
    End Sub
    Private Sub addIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean)
        Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace)
        If intent.PointOnSheet Is Nothing Then Return
        If onLineCheck Then
            If (IntentIsOnCurve(intent)) Then
                _intents.Add(intent)
        Else
    End Sub
    Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean
        Dim Geometry As DrawingCurve = intent.Geometry
        Dim sp = intent.PointOnSheet
        Dim pts(1) As Double
        Dim gp() As Double = {}
        Dim md() As Double = {}
        Dim pm() As Double = {}
        Dim st() As SolutionNatureEnum = {}
        pts(0) = sp.X
        pts(1) = sp.Y
        Try
            Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st)
        Catch ex As Exception
            Return False
        End Try
        Return True
    End Function
    Private Sub CreateIntentList()
        For Each oDrawingCurve As DrawingCurve In _view.DrawingCurves
            Select Case oDrawingCurve.ProjectedCurveType
                Case _
                        Curve2dTypeEnum.kCircleCurve2d,
                        Curve2dTypeEnum.kCircularArcCurve2d,
                        Curve2dTypeEnum.kEllipseFullCurve2d,
                        Curve2dTypeEnum.kEllipticalArcCurve2d
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularTopPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularRightPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent, False)
                    addIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent, False)
                Case _
                        Curve2dTypeEnum.kLineCurve2d,
                        Curve2dTypeEnum.kLineSegmentCurve2d
                Case _
                    Curve2dTypeEnum.kPolylineCurve2d,
                    Curve2dTypeEnum.kBSplineCurve2d,
                    Curve2dTypeEnum.kUnknownCurve2d
                    ' Unhandled curves types
                Case Else
            End Select
        Next
    End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
