How to use a TextureMap Object on the face
AlexShtol
AlexShtol
How to use a TextureMap Object on the face. There is no detailed information in Help API.
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
Set oCompDef = oDoc.ComponentDefinition
Dim oBody As SurfaceBody
Set oBody = oCompDef.SurfaceBodies.Item(1)
Dim oFace As Face
For i = 1 To oBody.Faces.Count
Set oFace = oBody.Faces.Item(i)
Next
Dim oTextureMap As TextureMap
Set oTextureMap = oFace.TextureMaps.Item(1)    /The program gives an error (Object variable not set (Error 91)
Object variable or With block variable not set)
t_hascj
Hi AlexShtol,
Are you sure that in TextureMaps is not null?
Try to add this code before.
If (oFace.TextureMaps Is Nothing)
Jaroslav
AlexShtol
Maybe I misunderstand what a Texture map is. For example, a detail that has faces with different textures. How to access the texture object.
Thanks for the help
t_hascj
Hi AlexShtol,
How you applied the texture on faces?
1. By appearrance, then TextureMaps is null(nothing). You need to get Appearance of face, if you want information about texture. Look at http://help-staging.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-6C856740-04CF-4601-88FA-863C0A9604... how to get information about texture from Asset object.
2. By Decal feature, then TextureMaps return texture/s. Look at https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014... how to add decal.
Jaroslav
AlexShtol
Thank you very much. You helped me a lot.
Maxim-CADman77
When somebody's answer leads your to a solution it is recommended to mark that answer as a solution (then others who are willing to help wouldn't spend time reading the no-actual threads)...
The best bet is to share final (fixed) edition of the code.
Please vote for Inventor-Idea Text Search within Option Names
