How to update document assets from library?
C-Hoppen
C-Hoppen
this always crashes
Inventor.PartDocument partDocument = (Inventor.PartDocument)refDocument;
List<Inventor.Asset> updateList = new List<Inventor.Asset>();
foreach (Inventor.MaterialAsset materialAsset in partDocument.MaterialAssets)
	try
		updateList.Add(oApp.ActiveMaterialLibrary.MaterialAssets[materialAsset.DisplayName]);
	catch { }
foreach (Inventor.Asset asset in updateList)
	try
		asset.CopyTo(partDocument, ReplaceExisting: true); // <---- THROWS AN EXCEPTION
	catch { }
 What could be the reason for this problem?
Chris
C-Hoppen
I tried to do it with VBA but same problem.
I noticed that there is a difference in the signature of CopyTo between VBA and the API doc.
API
ReplaceExisting: Optional input Boolean that specifies whether replace the existing asset if an asset of the same name exists.
VBA
So I tried this
Dim docMaterial As MaterialAsset
Set docMaterial = ThisDocument.ActiveMaterial
Dim libMaterial As MaterialAsset
Set libMaterial = ThisApplication.ActiveMaterialLibrary.MaterialAssets.Item(docMaterial.DisplayName)
Set docMaterial = libMaterial.CopyTo(ThisDocument.MaterialAssets, docMaterial)
and this
Dim docMaterial As asset // <-- why does this always turn to lower case?
Dim libMaterial As asset
Set docMaterial = libMaterial.CopyTo(ThisDocument.Assets, docMaterial)
and this (as desribed in the API docs)
Set docMaterial = libMaterial.CopyTo(ThisDocument.Assets, True)
and it always chrashes at CopyTo.
How can I update a existing MaterialAsset from a library?
Christoph
C-Hoppen
Added:
This question also relates to AppearanceAsset. Same Problem!
I can update the one active material by
ThisDocument.ComponentDefinition.Material.UpdateFromGlobal
but this doesn't update the materials appearance.
c_hoppen
Is there no solution? I need to update Material and Appearance Assets?
Regards
Christoph
mfoster9TD82
I'm running into this issue also. Did you ever find a solution?
