how to turn off Multiple Path Warning in Cable and Harness
liminma8458
liminma8458
Hi, everyone,
I am using "Automatic Route" button for a wire in Cable and Harness. Because the wire will be routed through many segments, a "Multiple Path Warning" will show up repeatedly, but I will click "OK" anyway and normally the right route will result. I would like to disable the warning. I tried "ThisApplication.SilentOperation = True" but it did not work out.
So how can I disable the  "Multiple Path Warning" prompt in cable and harness?
Thank you very much!
Limin
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @liminma8458,
Cable and Harness is a separate Add-In and extra feature from Autodesk. Unfortunately, still Inventor API does not support Cable and Harness Add-In.
So, warning message can not be turn off through API.
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
