Thanks for quick response and your tremendous knowledge
Solution is looks very simply to supress but to retain by using options .
I believe if I accept the solution , my idea of will be supressed and I really want gain some more knowledge from this forum
Let me brief , my requirement
1. I am verge of Semi automate the Panel assembly Which is shown in Image : AS000001
2. Subassembly which is AS005000 need supress by using TRUE/False in Main assembly AS000001 by using I logic
3. the main idea behind supress "AS005000" dividing the partions , next level door design
4. If I could supress the "AS005000" , next step I would supress the cut out aswell
5. It cant be done Level of details , Coz someone use the MAster model without any knowledge of parametric
shall be able to use it with min Conditions by selecting the Multi values in parametric
hope I have done my best to brief my idea behind suppress
In simple language
If my Parameter : DR_RTN_FRT= True/ False
if its true the assembly "AS005000 " should appear
If its False he assembly "AS005000 " should suppress
(DR_RTN_FRT ) is nothing but DOOR FRONT RETAINER
if some could help simple I logic rules would be much appreciated without Level of details
Vijay
