how to suppress multiple part using vba
The code below is working fine for selecting 3 parts
' To suppress a part
Public Sub AssemblyCount()
    ' Set reference to active document.
    ' This assumes the active document is an assembly
    Dim oDoc As Inventor.AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim selset As SelectSet
    Dim compOcc As ComponentOccurrence
    oDoc.SelectSet.Clear
    MsgBox ("Select a Part or a Subassembly")
    Do Until oDoc.SelectSet.Count = 3
        DoEvents    ' Yield to other processes.
    Loop
    Set selset = oDoc.SelectSet
    Dim obj As Object
    For Each obj In selset
        If TypeOf obj Is ComponentOccurrence Then
               Set compOcc = obj
               compOcc.Suppress
    Next
End Sub
But i want to select multiple parts until i hit enter button after hitting enter button all the selected parts must be suppressed
I tried the Application.onkey
Public enterWasPressed As Boolean
    enterWasPressed = False
    Do Until enterWasPressed = True
        Application.OnKey "{ENTER}", "recordEnterKeypress"
    Loop
    Dim obj As Object
               Set compOcc = obj
               compOcc.Suppress
    Next
End Sub
Sub recordEnterKeypress()
End Sub
but i am getting runtime error '424' object required can anyone please help me to fix my issue
CCarreiras
Hi!
Why don't you use iLogic.... a lot more simple to achieve that...
CCarreiras
I need to use VBA and learn it because it has lot more capabilites.
rjay75
Just an FYI everything you can do in VBA you can do in iLogic.
Second your VBA code. The Application object will use the Inventor Application. In which there is no OnKey event to hook to through VBA.
An alternate work flow is to run your VBA code after the objects have been selected.
VBA Code
    If selset.Count > 0 Then
    Dim obj As Object
               Set compOcc = obj
               compOcc.Suppress
    Next
End Sub
Then if you want to do the same with an iLogic rule.
Dim obj As Object
           compOcc = obj
           compOcc.Suppress
Next
The only change was to take it out of a Sub routine and remove the keyword set.
Thanks for your reply.But my requirement is slightly different. First i need to press a command button in the user form and then go to inventor to select the part or assemblies so that it can be suppressed. Actually the code is to be written in the command button.
rjay75
I understand now. You can still do it through the command button. I recommend that you use SelectEvents for object selection. A plus of this is you can set a filter to only allow selection of components. You can still use the same button to start and stop object selection. Just set a variable to state you're in selection mode and start the selection event. Then when the button is pressed again stop the selection event and process the selection. I use this method alot. It's also similar to existing Inventor behavior when you select the arrow buttons in certain command dialogs.
Look at the SelectEvents sample in the api.
If the only reason you want to use VBA instead of iLogics is to add the button in the ribbon, here's a small macro that will launch an iLogic rule:
Sub StartRule()
Dim iLogicAddinGuid As String
iLogicAddinGuid = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}"
Dim addin As Inventor.ApplicationAddIn
Dim tempaddin As Inventor.ApplicationAddIn
For Each addin In ThisApplication.ApplicationAddIns
If addin.ClassIdString = iLogicAddinGuid Then
Exit For
Next
If (addin.Activated = False) Then
addin.Activate
addin.Automation.RunRule ThisApplication.ActiveDocument, "MyRule"
End Sub
Naturally, you will need to change the "MyRule" for your rule name, but it should work.
