How to start Inventor with VB.NET in a different language?
Hi to all, is there a way to open Inventor.exe in different language (English or French)?  I already loaded the French Language pack.
See below part of a VB.NET program:
Imports System
Imports System.Type
Imports System.Activator
Imports System.Runtime.InteropServices
Imports Inventor
Public Class Form1
   Dim _invApp As Inventor.Application
   Dim _started As Boolean
   Public Sub New()
       ' This call is required by the designer.
       InitializeComponent()
       ' Add any initialization after the InitializeComponent() call.
       Try
           _invApp = Marshal.GetActiveObject("Inventor.Application")
       Catch ex As Exception
           Try
               Dim oInvAppType As Type = GetTypeFromProgID("Inventor.Application")
               _invApp = CreateInstance(oInvAppType)
               'I would like to select from the two below:
               'Shortcut English: Inventor shortcut "C:\Program Files\Autodesk\Inventor 2016\Bin\Inventor.exe" /language=ENU
               'Shortcut French: Inventor shortcut "C:\Program Files\Autodesk\Inventor 2016\Bin\Inventor.exe" /language=FRA
               _invApp.Visible = True
               'Note: if you shut down the Inventor session that was started
               'this(way) there is still an Inventor.exe running. We will use
               'this Boolean to test whether or not the Inventor App will
               'need to be shut down.
               _started = True
           Catch ex2 As Exception
               MsgBox(ex2.ToString())
               MsgBox("Unable to get or start Inventor")
           End Try
       End Try
       Me.TopMost = True
   End Sub
YuhanZhang
Currently a workaround maybe that you change the Inventor.ini file to switch the language for Inventor, you can find the Inventor.ini from the Inventor installation location, usually it is C:\Program Files\Autodesk\Inventor 201x\Bin\Inventor.ini. There is a setting DefaultLanguage=ENU, you can modify the language to switch it. Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Owner2229
You can start Inventor with Process.Start() and then get it with GetActiveObject():
Process.Start("C:\Program Files\Autodesk\Inventor 2016\Bin\Inventor.exe", " /language=FRA")
Threading.Thread.Sleep(1000) 'Give Inventor some time to start-up
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Hi Mike, that was a big help for me.
Thank's again!
Alain
