How to sort the balloons and the part list when the relationship between dwg and models is broken?
1354448288
1354448288
I have tried to change the balloons serial number(BalloonValueSets[1].Value), and successed, but I still noticed that:
when the relationship between dwg and models is broken, the partslist will not change the serial number while the bolloons(BalloonValueSets[1].Value) are changing.
now, my question is how to change both the partslist serial number and bolloons(BalloonValueSets[1].Value), when the relationship between the dwg and the models is broken.
A.Acheson
Can you explain a little more your desired workflow with an image? What is the end goal for your rule?
When you say relationship between model and drawing is broken is this intended? If you can provide an image that will be helpful.
Regards
Alan
