How to solve the problem of dimension lines appearing as dotted lines
ysbaodnj
Message 1 of 1
ysbaodnj
hello,
Create dimension lines for drawings using i-Logic code.
If you adjust the text position of the vertical dimension line, it will change to a dotted line.
All dimension line styles are the same, and when adjusting the text position of a horizontal dimension line, it appears as a solid line.
Please refer to the picture below.
Is it a program problem?
If not I need your help.
Replies (0)
