How to set dimension display as tolerance?
CadUser46
CadUser46
In part document setttings where you have the dimensiondisplayenum, how do i set these?  In particaular i want to set to kDimensionDisplayAsTolerance.
Inventor 2010 Certified Professional
Currently using 2023 Pro
philippe.leefsma
If you look in the Help Files for DimensionDisplayTypeEnum, the only property of this type is Parameters.DimensionDisplayType.
So can access that from PartDocument.ComponentDefinition.Parameters.DimensionDisplayType.
Hope that helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
CadUser46
Thanks Philippe. Not sure how i didnt join the dots to get the answer originally.
opartdoc.ComponentDefinition.Parameters.DimensionDisplayType = kDimensionDisplayAsTolerance
