How to select face first and set a new base before continue measure with code give
syafiqfarhan
syafiqfarhan
I have one simple question,
Currently, I try to create new iproperties using ilogic (code below). but I face issues if the part is not on the proper USC.
Please help me how can do selection first (red arrow) and set a new base before creating a new iproperties
iProperties.Value("Custom", "t") = Round(MinOfMany(Measure.ExtentsHeight, Measure.ExtentsLength, Measure.ExtentsWidth))
iProperties.Value("Custom", "l") = Round(MaxOfMany(Measure.ExtentsHeight, Measure.ExtentsLength, Measure.ExtentsWidth))
If iProperties.Value("Custom", "t") = Round(Measure.ExtentsWidth) And iProperties.Value("Custom", "l") = Round(Measure.ExtentsHeight) Then iProperties.Value("Custom", "w") = Round(Measure.ExtentsLength) Else
If iProperties.Value("Custom", "t") = Round(Measure.ExtentsWidth) And iProperties.Value("Custom", "l") = Round(Measure.ExtentsLength) Then iProperties.Value("Custom", "w") = Round(Measure.ExtentsHeight) Else
If iProperties.Value("Custom", "t") = Round(Measure.ExtentsHeight) And iProperties.Value("Custom", "l") = Round(Measure.ExtentsLength) Then iProperties.Value("Custom", "w") = Round(Measure.ExtentsWidth) Else
If iProperties.Value("Custom", "t") = Round(Measure.ExtentsHeight) And iProperties.Value("Custom", "l") = Round(Measure.ExtentsWidth) Then iProperties.Value("Custom", "w") = Round(Measure.ExtentsLength) Else
If iProperties.Value("Custom", "t") = Round(Measure.ExtentsLength) And iProperties.Value("Custom", "l") = Round(Measure.ExtentsWidth) Then iProperties.Value("Custom", "w") = Round(Measure.ExtentsHeight) Else
If iProperties.Value("Custom", "t") = Round(Measure.ExtentsLength) And iProperties.Value("Custom", "l") = Round(Measure.ExtentsHeight) Then iProperties.Value("Custom", "w") = Round(Measure.ExtentsWidth)
theo.bot
the measurement is based on the XYZ axis. so it's difficult to get the accurate measurement for an object that is not aligned with the XYZ axis. You could consider aligning the body before using measure. also take a look at this blog: Mod the Machine: Getting the Overall Size of Parts (typepad.com)
syafiqfarhan
Ok, Understood. That means I need to change the USC to make sure the object aligns with the XYZ axis.
Public Sub TestTightBoundingBox()
    Dim invApp As Inventor.Application = GetObject(, "Inventor.Application")
    ' Have a body selected.
    Dim body As SurfaceBody
    body = invApp.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select the body.")
    ' Call the function to get the tight bounding box.
    Dim bndBox As Box = calculateTightBoundingBox(body)
    ' Draw the bounding box using a 3D sketch.
    Dim partDoc As PartDocument = invApp.ActiveDocument
    Dim sk As Sketch3D = partDoc.ComponentDefinition.Sketches3D.Add()
    Dim lines As SketchLines3D = sk.SketchLines3D
    Dim tg As TransientGeometry = invApp.TransientGeometry
    Dim minXYZ As Point = bndBox.MinPoint
    Dim minXYmaxZ As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MinPoint.Y, bndBox.MaxPoint.Z)
    Dim minXmaxYZ As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MaxPoint.Y, bndBox.MaxPoint.Z)
    Dim minXZmaxY As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MaxPoint.Y, bndBox.MinPoint.Z)
    Dim maxXYZ As Point = bndBox.MaxPoint
    Dim maxXYminZ As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MaxPoint.Y, bndBox.MinPoint.Z)
    Dim maxXZminY As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MinPoint.Y, bndBox.MaxPoint.Z)
    Dim maxXminYZ As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MinPoint.Y, bndBox.MinPoint.Z)
    lines.AddByTwoPoints(minXYZ, minXYmaxZ)
    lines.AddByTwoPoints(minXYZ, minXZmaxY)
    lines.AddByTwoPoints(minXZmaxY, minXmaxYZ)
    lines.AddByTwoPoints(minXYmaxZ, minXmaxYZ)
    lines.AddByTwoPoints(maxXYZ, maxXYminZ)
    lines.AddByTwoPoints(maxXYZ, maxXZminY)
    lines.AddByTwoPoints(maxXYminZ, maxXminYZ)
    lines.AddByTwoPoints(maxXZminY, maxXminYZ)
    lines.AddByTwoPoints(minXYZ, maxXminYZ)
    lines.AddByTwoPoints(minXYmaxZ, maxXZminY)
    lines.AddByTwoPoints(minXmaxYZ, maxXYZ)
    lines.AddByTwoPoints(minXZmaxY, maxXYminZ)
End Sub
' Calculates a tight bounding box around the input body.  An optional
' tolerance argument is available.  This specificies the tolerance in
' centimeters.  If not provided the best existing display mesh is used.
Public Function calculateTightBoundingBox(body As SurfaceBody, Optional Tolerance As Double = 0) As Box
    Try
        Dim vertCount As Integer
        Dim facetCount As Integer
        Dim vertCoords() As Double = {}
        Dim normVectors() As Double = {}
        Dim vertInds() As Integer = {}
        ' If the tolerance is zero, use the best display mesh available.
        If Tolerance <= 0 Then
            ' Get the best display mesh available.
            Dim tolCount As Long
            Dim tols() As Double = {}
            Call body.GetExistingFacetTolerances(tolCount, tols)
            Dim bestTol As Double
            bestTol = tols(0)
            For i As Integer = 1 To tolCount - 1
                If tols(i) < bestTol Then
                    bestTol = tols(i)
            Next
            body.GetExistingFacets(bestTol, vertCount, facetCount, vertCoords, normVectors, vertInds)
        Else
            ' Calculate a new mesh based on the input tolerance.
            body.CalculateFacets(Tolerance, vertCount, facetCount, vertCoords, normVectors, vertInds)
        Dim tg As TransientGeometry = body.Application.TransientGeometry
        ' Calculate the range of the mesh.
        Dim smallPnt As Point = tg.CreatePoint(vertCoords(0), vertCoords(1), vertCoords(2))
        Dim largePnt As Point = tg.CreatePoint(vertCoords(0), vertCoords(1), vertCoords(2))
        For i As Integer = 1 To vertCount - 1
            Dim vertX As Double = vertCoords(i * 3)
            Dim vertY As Double = vertCoords(i * 3 + 1)
            Dim vertZ As Double = vertCoords(i * 3 + 2)
            If vertX < smallPnt.X Then
                smallPnt.X = vertX
            If vertY < smallPnt.Y Then
                smallPnt.Y = vertY
            If vertZ < smallPnt.Z Then
                smallPnt.Z = vertZ
            If vertX > largePnt.X Then
                largePnt.X = vertX
            If vertY > largePnt.Y Then
                largePnt.Y = vertY
            If vertZ > largePnt.Z Then
                largePnt.Z = vertZ
        Next
        ' Create and return a Box as the result.
        Dim newBox As Box = tg.CreateBox()
        newBox.MinPoint = smallPnt
        newBox.MaxPoint = largePnt
        Return newBox
    Catch ex As Exception
        Return Nothing
    End Try
End Function
I try to copy-paste into my Inventor rules but it shows
theo.bot
replace your first line with "sub main" and the code will work.
But if you have read the entire blog, brian mentioned he was not going into detail about repositioning of an object.
"The ability to automatically calculate a bounding box that is oriented to get the tightest fitting box possible is a very difficult problem that I haven’t seen a solution to. It’s something you could probably write a PhD paper on. The easiest approach to the orientation problem is to ask the user for help by lettin them define the coordinate system the bounding box should be calculated in, essentially defining the directions for the length, width and height. That’s possible but a little more than I wanted to go into in this post so I’ll limit this discussion to calculating a tight fitting bounding box that’s oriented parallel to the world XYZ planes"
_dscholtes_
If you're using Inventor v2020 and up, a new feature is introduced which takes care of the orientation problem. It returns the smallest box in which the part will fit. See this post by DRoam in another thread.
theo.bot
@_dscholtes_
Thx! I wasn't aware of this.
