How to save a file with a different name by use parameter as the file name?
pong2474
pong2474
file name ex) AAA-"LENGTH"-BBB → "LENGTH"
d_eckel
Hi, maybe something like this:
Dim oDoc As Document = ThisDoc.Document
Dim oMyParameter As UserParameters = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
'check file type and set dialog filter
Dim Filetype As String
If oDoc.DocumentType = kPartDocumentObject Then
    Filetype = ".ipt"
ElseIf oDoc.DocumentType = kAssemblyDocumentObject Then
    Filetype = ".iam"
ElseIf oDoc.DocumentType = kDrawingDocumentObject Then
    Filetype = ".idw"
oDoc.SaveAs("C:\temp\" & oMyParameter.Item("SaveName").Value & Filetype, 0)
 with the user Paramter as a TextParameter:
I don't really understand the way qou want to name the file, described in the description.
If your Paramter is a number, you need the convert it from number to string with
CDblAny(oMyParameter.Item("SaveName").Value)
 in the last line.
I hope it helps you a little bit.
