How to run my ilogic on all parts in assembly?
kleiton.narcizo
kleiton.narcizo
I use this code to get information of each piece, but I want to run it from the assembly, does anyone know how?
SyntaxEditor Code Snippet
ESPESSURA = SheetMetal.GetActiveStyle()
COMPRIMENTO = Round (SheetMetal.FlatExtentsLength, 0)
LARGURA = Round (SheetMetal.FlatExtentsWidth,0)
MATERIAL = iProperties.Material
FATORK = SheetMetal.ActiveKFactor
If COMPRIMENTO<=LARGURA  Then
TESTE = MATERIAL & " E=" & ESPESSURA & " L=" & COMPRIMENTO & " C=" & LARGURA & " FK=" & FATORK
If COMPRIMENTO>=LARGURA  Then
TESTE = MATERIAL & " E=" & ESPESSURA & " L=" & LARGURA & " C=" & COMPRIMENTO & " FK=" & FATORK
b_sharanraj
Hi @kleiton.narcizo
Does this code added in all the parts of your Master Assembly and Sub Assembly?
Regards
B.Sharan Raj
This should do the trick when run from an assembly. I assumed you may have other non-sheet metal parts in the assembly, so I filtered only the sheet metal parts, another assumption made is that all the sheet metal parts have a flat pattern. Let me know how you get on with it:
' Get the active assembly.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
' Get all of the referenced documents.
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
' Iterate through the list of documents.
Dim oRefDoc As Document
' Check for a non-part document
If oAsmDoc.DocumentType <> kAssemblyDocumentObject Then
    MsgBox ("The Active document must be an 'Assembly'!")
    Exit Sub
' Iterate through all referenced documents beneath the active assembly
For Each oRefDoc In oRefDocs
    ' Set a reference to the design tracking property set object.
    oPropertySet = oRefDoc.PropertySets.Item("Design Tracking Properties")
    If oRefDoc.ComponentDefinition.Document.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
        Dim ESPESSURA As String = oRefDoc.ComponentDefinition.ActiveSheetMetalStyle.Name
        ' Get SheetMetalLength property
        Dim strCOMPRIMENTO As String = oPropertySet.Item(50).Value
        ' Convert to a rounded number
        Dim COMPRIMENTO As Decimal = Round(Decimal.Parse(strCOMPRIMENTO.Remove(strCOMPRIMENTO.Length - 2)),0)
        ' Get SheetMetalWidth property
        Dim strLARGURA As String = oPropertySet.Item(49).Value
        Dim LARGURA As Decimal = Round(Decimal.Parse(strLARGURA.Remove(strLARGURA.Length - 2)),0)
        ' Get document material
        Dim MATERIAL As String = oRefDoc.ComponentDefinition.Material.Name
        ' Get document Kfactor
        Dim FATORK As String = oRefDoc.ComponentDefinition.UnfoldMethod.KFactor
        'MsgBox(TESTE)
Next
P.S. This will search through all referenced documents in the active assembly, so will include any parts in sub-assemblies.
