How to Renumber Itens in the Structured View
gustavo.cassel
gustavo.cassel
Hello, i'm trying to renumber the itens in the Strucured View in a Assembly with a VBA Macro.
But with this line of code:
Dim oAsm As AssemblyDocument
Set oAsm = ThisApplication.ActiveDocument
Dim oBOM As BOM
Set oBOM = oAsm.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = False
Dim oBOMView As BOMView
Set oBOMView = oBOM.BOMViews("Structured")
oBOMView.Renumber(1, 1)
I got an error called "Compile error: Expected : =".
Can someone tell me how i renumber the itens in the structured view of an assembly with VBA?
JelteDeJong
I think you should be using a "call". like this:
Dim oBOM As BOM
call oBOMView.Renumber(1, 1)
But I wonder why you write VBa code. Check this blog post: "Is VBA in Inventor obsolete?".
Jelte de Jong
Blog: hjalte.nl - github.com
gustavo.cassel
I've tryied this before! It continue giving me this error, can you help me?
JelteDeJong
This works as an iLogic rule:
Dim oAsm As AssemblyDocument = ThisApplication.ActiveDocument
Dim oBOM As BOM = oAsm.ComponentDefinition.BOM
Dim oBOMView As BOMView = oBOM.BOMViews("Structured")
 (Sorry I did not install VBa so i can't test VBa code)
Jelte de Jong
gustavo.cassel
I see that this works as a iLogic Rule, but i still need a version of he that works with VBA. The BOMView.Renumber method seems have a syntax error and its not working. If someone knows how to make it works, i'll be happy to know too.
Ralf_Krieg
Hello
EDIT: Seen right now, Jelte wrote you exact the same VBA code. Can you post the error message?
As VBA:
Private Sub RenumberBOM()
Dim oBOM As BOM
Set oBOMView = oBOM.BOMViews("Structured") '<-- the name is localized !!!
Call oBOMView.Renumber(1, 1)
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
gustavo.cassel
I don't know why, but this time it works. I've just closed the Inventor and opened it again and it works. I hate this thing.
Thank you guys, you helped me so much!!
