How to rename the workplanes using ilogic for features created in flat pattern
I used below code for renaming work planes in Sheet metal flatpattern tree but it renaming in model tree but not in flatpattern tree.
Can anyone help me to rename the planes in flatpattern tree?
SyntaxEditor Code Snippet
'Rename work planes
oDoc = ThisApplication.activedocument
i = 1
For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
    If oWorkPlane.IsCoordinateSystemElement = False Then
    oWorkPlane.Name = "WorkPlane" & i
    i=i+1
Next
t_hascj
If you want to edit workplanes in flat pattern, you need flat pattern object. Try this code.
'Rename work planes
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
i = 1
For Each oWorkPlane In oCompDef.WorkPlanes
    i=i+1
Next
i = 1
For Each oWorkPlane In oCompDef.FlatPattern.WorkPlanes
    i=i+1
Next
Jaroslav
Hello Jaroslav,
Thank you its working fine.
I have a doubt, is it possible to create Workplanes to Origin in Flatpattern model tree using iLogic?
t_hascj
I think it is possible, but you need more inputs. Not only origin. Look at this documentation about Workplanes. There is some create methods.
