How to read Logger.Info?
wowrs1608
wowrs1608
New to iLogic. From here, http://www.hjalte.nl/60-creating-an-inventor-addin , I got this code:
For Each ribbon As Ribbon In ThisApplication.UserInterfaceManager.Ribbons
    Logger.Info(vbTab & Ribbon.InternalName)
    For Each ribbonTab As RibbonTab In Ribbon.RibbonTabs
        Logger.Info(vbTab & vbTab & RibbonTab.DisplayName & " - " & RibbonTab.InternalName)
        For Each ribbonPanel As RibbonPanel In RibbonTab.RibbonPanels
            Logger.Info(vbTab & vbTab & vbTab & RibbonPanel.DisplayName & " - " & RibbonPanel.InternalName)
        Next
    Next
Next
I opened an asssembly file. Under Manage/iLogic/Add Rule,I added it. And Save & Run.
Where do I read the output? Thanks for help.
Cheers,
Pete
Curtis_Waguespack
Hi @wowrs1608
Click the + sign next to the Model browser, and then choose iLogic Log from the list.
Or you can use something like this to toggle it on/of
For Each oDockableWindow As Inventor.DockableWindow In ThisApplication.UserInterfaceManager.DockableWindows
	If oDockableWindow.InternalName = "ilogic.logwindow" Then
		oDockableWindow.Visible = Not oDockableWindow.Visible
Next
Or something like this to turn it on
		oDockableWindow.Visible = True
Next
 I hope this helps.
Curtis
wowrs1608
Thank you very much. I can read the output now.
JelteDeJong
I like the code that @Curtis_Waguespack proposed, and I have added it to the blog post. (However, with a small twist. It is possible to do it without a loop and if statement. I think it looks cleaner)
Regarding the question in your mail. I expect that your name for the ribbon panel is wrong. As far as I can see the name "Position.RibbonPanel" is not a default name. I expect that you need the name: "id_PanelA_AssemblePosition"
Jelte de Jong
Blog: hjalte.nl - github.com
wowrs1608
Yes, I have found that out. Assembly and Part looks like different products - Following different naming pattern.
Thanks your code, I have added a few buttons.
