How to prompt user to select a folder directory for saving files in VBA
jake_egley
Message 1 of 8
jake_egley
I have my export dxf code and I want the user to be prompted to select the directory for where to save the dxf.
This is what I got now, but it only works when you type a file name and I don't want the user to have to type a file name, Im not going to use the typed file name anyways.
Dim oFileDirMan As String
Dim oFileDlg As FileDialog
Call ThisApplication.CreateFileDialog(oFileDlg)
oFileDlg.MultiSelectEnabled = False
oFileDlg.CancelError = False
oFileDlg.DialogTitle = "Save Where"
oFileDlg.FileName = "Please choose a directory..."
oFileDlg.ShowSave
oFileDirMan = oFileDlg.FileName & "\"
MsgBox (oFileDirMan)
Appreciate any help.
Jake Egley
Inventor 2022
Replies (7)
Message 2 of 8
C_Haines_ENG
Message 3 of 8
C_Haines_ENG
If that doesn't work, you can try this:
Dim objShell As Object
objShell = CreateObject(“Shell.Application”)
objFolder = objShell.BrowseForFolder(0, "", 0, “C:\”)
If objFolder Is Nothing Then Exit Sub
Dim oPath As String
oPath = objFolder.Self.Path
MsgBox(oPath)
 I don't do Inventor code in Visual Studio so this may not work.
Message 4 of 8
jake_egley
I'm using visual basic for my code instead of iLogic. Sadly none of that code works nor can I adapt it. I found this but cant get it to work since shell and folder are not objects in inventor visual basic.
This is the visual basic code from the article but it doesn't work due to the objects not existing:
    Dim objShell   As Shell
    Dim ssfWINDOWS As Long
    Dim objFolder  As Folder
    ssfWINDOWS = 36
    Set objShell = New Shell
        Set objFolder = objShell.BrowseForFolder(0, "Example", 0, ssfWINDOWS)
            If (Not objFolder Is Nothing) Then
                'Add code here
        Set objFolder = Nothing
    Set objShell = Nothing
Jake Egley
Inventor 2022
Message 5 of 8
C_Haines_ENG
You will need to import Shell.
Maybe this video will help.
Message 6 of 8
jake_egley
Tried that but when I go to tools>references it is grayed out, so I can't import shell.
Jake Egley
Inventor 2022
Message 7 of 8
C_Haines_ENG
How about this code. I got this working in VBA. I assume you're doing this from Excel.
Dim objFolder As Object
Dim strFolderFullPath As String
Sub FolderBrowser()
    'Sub-routine to open a file browser
    'The starting point of the browser is hard-coded.
    Dim objShell As Object, OpenAt As Variant
    'The file browser starting point can be changed in the line below
    OpenAt = "C:\Documents and Settings\tcbealdk\My Documents\"
    Set objShell = CreateObject("Shell.Application")
    Set objFolder = objShell.BrowseForFolder(0, "Please browse to or create a folder", 0, "C:\")
    '~~> If user presses cancel
        MsgBox "User Pressed Cancel"
    Else
        strFolderFullPath = objFolder.Items.Item.Path
        MsgBox ("the folder is: " & strFolderFullPath)
End Sub
Message 8 of 8
jake_egley
Works perfect, thank you
Jake Egley
Inventor 2022
