How to programmatically cancel a ControlDefinition?
nannerdw
nannerdw
I can't figure out how to execute a control definition more than once without user interaction.  The example code below only works when I press the escape key multiple times.
I'm using control definitions to add constraints, because I couldn't get SketchBlockDefinition.GeometricConstraints to work.
I'm using Inventor 2020 - Build 168
'This iLogic code adds horizontal and vertical constraints to the selected lines.
Option Explicit On
Imports System.Linq
Dim app As Inventor.Application = ThisApplication Dim doc As Document = ThisDoc.Document Dim selSet As SelectSet = doc.SelectSet Dim cmdMgr As CommandManager = app.CommandManager Dim ctrlDefs As ControlDefinitions = cmdMgr.ControlDefinitions Dim i As Integer = 0 For Each oSketchLine In selSet.OfType(Of SketchLine).ToList selSet.Clear selSet.Select(oSketchLine) If i Mod 2 = 0 Then ctrlDefs("SketchHorizontalConstraintCmd").Execute2(True) Else ctrlDefs("SketchVerticalConstraintCmd").Execute2(True) End If i+=1 Next
This example uses GeometricConstraints:
'This iLogic code is supposed to add horizontal constraints to all lines in the active sketch,
'sketch block, or sketch block definition. It only works in a sketch.
Option Explicit On
Dim activatedObject As Object = doc.ActivatedObject
Dim oSketchLines As SketchLines
Dim gc As GeometricConstraints
If activatedObject.Type = kSketchBlockObject Then
	Dim def As SketchBlockDefinition = activatedObject.Definition
	gc = def.GeometricConstraints
	oSketchLines =def.SketchLines
Else
	gc = activatedObject.GeometricConstraints
	oSketchLines = activatedObject.SketchLines
For Each tmpLine As SketchLine In oSketchLines
	gc.AddHorizontal(tmpLine)
Next
chandra.shekar.g
Autodesk Support
Autodesk Support
@nannerdw,
Hoping that below control definition may be useful.
ctrlDefs("AppContextual_CancelCmd").Execute2(True)
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
JelteDeJong
this iLogic rule will add a horizontal constaint to all sketch lines in a sketch that is activated.
Dim doc As PartDocument = ThisApplication.ActiveDocument
If (doc.SketchActive = False) Then
    MsgBox("None sketch active")
Dim Sketch As PlanarSketch = doc.ActivatedObject
Dim geomConstraints As GeometricConstraints = Sketch.GeometricConstraints
For Each line As SketchLine In Sketch.SketchLines
    geomConstraints.AddHorizontal(line)
Next
Jelte de Jong
Blog: hjalte.nl - github.com
nannerdw
That is the same method as the second example that I already posted.  It does not work inside sketch blocks.
I'm using control definitions to add constraints, because I couldn't get "SketchBlockDefinition.GeometricConstraints" to work.
nannerdw
Adding "AppContextual_CancelCmd" causes only the first constraint to be automatically created, then it just switches to the manual command after that.  If I instead press Esc multiple times, it continues adding all of the automatic constraints, but only if I keep manually pressing Esc repeatedly, the same as what my first example did.
JelteDeJong
I assumed wrong that you where creating a sketch. Maby this helps:
Dim blockName = "Block1"
Dim sketchBlock As SketchBlockDefinition = doc.ComponentDefinition.SketchBlockDefinitions.Item(blockName)
Dim geomConstraints As GeometricConstraints = sketchBlock.GeometricConstraints
For Each line As SketchLine In sketchBlock.SketchLines
Next
Jelte de Jong
