How to print an invisble oependeIDW
in Inventor 2009 i want to print some known idw's out of an Partlist.
AI open this files with
Set oDoc_Idw = oApp.Documents.Open(sIDWName, False)
After that i try to print with oDoc_Idw.PrintManager but nothing happend.
If the file is opened visible with
Set oDoc_Idw = oApp.Documents.Open(sIDWName, True)
the same code works well and files ar printed as intended.
Is there any way to print invisible opened IDW Files?
I thougth it would run much more faster and can be done in background?
Any advice?
Ralf
I am not positive but I do believe that you can't print invisible files as
you have found. But why not use Apprentice instead. Then you don't even
need Inventor running.
KWiKMcad
Kent Keller
"r.g." wrote in message
news:6345527@discussion.autodesk.com...
Any advice?
Ralf
thank's Kent for your hint but i thougt Apprentice would'nt work within a
vba makro? Hopefully i dont have to write an addin only because of this
little task. Am i right with vba an Apprentice? Ralf
Am 27.02.2010, 17:03 Uhr, schrieb Kent :
> as
Erstellt mit Operas revolutionärem E-Mail-Modul: http://www.opera.com/mail/
