how to prevent double click a user defined button in an addin?
liminma8458
liminma8458
hi,
I create a button in the Inventor Ribbon interface through VB.NET addin, then the button to call a form (my_aaa) using such:
Private Sub m_button_test_OnExecute(ByVal Context As Inventor.NameValueMap) Handles m_button_test.OnExecute
      Dim my_aaa As New form_aaa
      my_aaa.Show()
End sub
One click to the button will create the form my_aaa. The problem is when user accidentally double-click the button, 2 forms (my_aaa) will appear. He has to close one and carry on the other. That will cause failure problem for our codes afterward. Is that possible to prevent double clicking on the botton (an Inventor's OnExecute event) or let Inventor treats double click as single click on this button.
Thanks in advance
Limin
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
xiaodong_liang
Autodesk Support
Autodesk Support
it is the responsibility of your code to handle the workflow, instead of Inventor. The following code snippet is for your reference:
' define my_aaa as global variable in your class
Dim my_aaa As form_aaa
If _MainForm Is Nothing Then
my_aaa = New form_aaa()
my_aaa .Show()
End sub
I also strongly suggest you take a look at the tutorial on Best Practices for Add-In Programming and Design Patterns, which provides the nice template to manage addin button, modeless dialog etc.
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/classes/year-2011/autodesk-inventor...
liminma8458
Hi, Liang
Thank you very much!
I found a solution by making some modification to your code, as follows:
If my_aaa Is Nothing Then
else
my_aaa.Close()
my_aaa.Show()
End sub
By doing that, one click or two click will result in one my_aaa form only.
Thanks Liang again. Cheers!
Limin
