How to plot all parts drawings in assembly?
mucip
mucip
Is it pssible to plot (or print) all sub assemblies or parts drawings in to  seperate pages by code?
I do not want to open and print every parts. One code and print all... Is it possible?
Mucip:)
skyngu
it is possible but also depends on the model of printer or plotter.
Autodesk Inventor Professional 2019
mucip
Dear Jcneal,
I just saw below post and apply:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Printing-all-drawings-of-an-assembly-f...
I assigned to printer to CutePDF printer. But unfortuatelly when I run the code Inventor crash!...
I just want to create pdf file first from the all asm file in to seperate part pdf drawings...
My Code is:
Sub PrintAll()
If MsgBox("Are you sure?", vbYesNo) = vbYes Then
'Opening all associated parts
'Get the active assembly.
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
'Get all of the referenced documents.
Dim oRefDocs As DocumentsEnumerator
Set oRefDocs = oAsmDoc.AllReferencedDocuments
'Iterate through the list of documents.
Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
'Debug.Print oRefDoc.FullFileName
'Open iam or ipt
Dim oDoc As Document
Set oDoc = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
oDoc.SelectSet.Select oDoc.ComponentDefinition
'Get the CommandManager object
Dim oCommandMgr As CommandManager
Set oCommandMgr = ThisApplication.CommandManager
'Get control definition for the line command
'Dim oControlDef As ControlDefinition
'Set oControlDef = oCommandMgr.ControlDefinitions.Item("AIMDOpenDrawingInContextMenuInternal")
Set oControlDef = oCommandMgr.ControlDefinitions.Item("CMxOpenDrawingCMD")
'Execute the command
Call oControlDef.Execute
'Print idw
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
Dim oDraw As Document
Set oDraw = ThisApplication.ActiveDocument
'MsgBox oDraw.FullFileName
Dim oDrgPrintMgr As DrawingPrintManager
Set oDrgPrintMgr = oDraw.PrintManager
'Set the printer name
oDrgPrintMgr.Printer = "CutePDF Writer"
oDrgPrintMgr.PrintRange = kPrintAllSheets
'Set the paper size and scale
On Error Resume Next
Select Case oDraw.ActiveSheet.Size
Case kA4DrawingSheetSize
oDrgPrintMgr.PaperSize = kPaperSizeA4
oDrgPrintMgr.ScaleMode = kPrintCustomScale
oDrgPrintMgr.[Scale] = 1
Case kA3DrawingSheetSize
oDrgPrintMgr.ScaleMode = kPrintBestFitScale
Case kA2DrawingSheetSize
oDrgPrintMgr.PaperSize = kPaperSizeA3
Case kA1DrawingSheetSize
Case kA0DrawingSheetSize
Case Else
'Debug.Print "ungültiges Papierformat"
End Select
'Set the paper orientation
Select Case oDraw.ActiveSheet.Orientation
Case kLandscapePageOrientation
oDrgPrintMgr.Orientation = kLandscapeOrientation
Case kPortraitPageOrientation
oDrgPrintMgr.Orientation = kPortraitOrientation
Case Else
'Debug.Print "ungültige Orientierung"
End Select
oDrgPrintMgr.SubmitPrint
'Close idw
oDraw.Close (True)
'Close iam or ipt
oDoc.Close (True)
Next
'Opening Asmdrawing in context menu
'Dim oDrgPrintMgr As DrawingPrintManager
Case Else
End Select
Case Else
End Select
'Close idw
oDraw.Close (True)
Else
'No
End Sub
skyngu
you only want pdfs from assembly. you may check out the post below.
http://forums.autodesk.com/t5/Autodesk-Inventor/Printing-drawing-sheet-sets-from-assembly-BOM-Parts-...
good luck!
mucip
Perfect solution... Thanks... 🙂
Mucip:)
mucip
I tested many times... But in some how in some files this code creating corruptud pdf files. For instance, the name of the ipt file is "PMD-01-01-01.ipt" but corrupted file name is "PMD-01-01pdf"?!... It must be "PMD-01-01-01.pdf" normally but in some files I got this error...
Any info?...
Mucip:)
skyngu
the post you read uses display name instead of filename. You may change code a liitle to suit your need
