How to pick(CommandManager.Pick) sub assembly then apply a custom iProperty
Preston_Reed
Preston_Reed
Hello, I am trying to make a rule where the user is prompted to select a particular sub assembly then it will apply values to its iProperties.  My issue is that if I use the method of CommandManager.Pick then I don't know how to apply a custom iproperty using oOccurrence.  Then if I want to use my typical method for applying custom iproperties via documents I don't know how to make the Pick in terms of document type.
So, is there a way to
a) apply custom iProperties through oOccurrence (Assembly to sub assembly/parts)
b) prompt a user to make a selection using document type
or if theres another way im all ears.
 Selection Method
' Selection
	Dim oOccurence As Inventor.ComponentOccurrence = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "select")
	Dim oAry As Array = Split(oOccurence.Name, ":")
	Dim oAsmDoc As Inventor.AssemblyDocument = ThisDoc.Document
	Dim oSlct As Inventor.SelectSet = oAsmDoc.SelectSet
	Dim oOccEnum As ComponentOccurrencesEnumerator = oAsmDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oOccurence.Definition)
	Dim oObjColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	For Each oOcc As ComponentOccurrence In oOccEnum
		oOcc.PropertySets("Inventor User Defined Properties").Item("S0Class").Value = "1"
	Next
Typically how I apply iprops to sub assemblies
For Each oRefDoc As Document In oRefDocs
		' Skipping any purchased or mfg parts / any parts that are not accessable
		If oRefDoc.IsModifiable() = True AndAlso oRefDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			Dim oCustomPropertySet As PropertySet
			oCustomPropertySet = ThisApplication.ActiveDocument.PropertySets.Item("Inventor User Defined Properties")
			Dim oCustProp As Inventor.Property
			For Each oCustProp In oCustomPropertySet
				oRefDoc.PropertySets("Inventor User Defined Properties").Item("CUSTOMER NAME-1").Value = CUSTOMERNAME1
				oRefDoc.PropertySets("Inventor User Defined Properties").Item("CUSTOMER PO#").Value = CUSTOMERPO
				oRefDoc.PropertySets("Inventor User Defined Properties").Item("END USER-1").Value = ENDUSER1
			Next
		Else
			' Do Nothing
	Next
JelteDeJong
You could try something like this:
Dim occ As ComponentOccurrence = ThisApplication.CommandManager.Pick(
    SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select your sub assembly")
Dim refDoc As Document = occ.ReferencedDocumentDescriptor.ReferencedDocument
Dim propSet As PropertySet = refDoc.PropertySets.Item("Inventor User Defined Properties")
propSet.Item("CUSTOMER NAME-1").Value = CUSTOMERNAME1
propSet.Item("CUSTOMER PO#").Value = CUSTOMERPO
propSet.Item("END USER-1").Value = ENDUSER1
Jelte de Jong
Blog: hjalte.nl - github.com
Preston_Reed
That worked perfectly, thank you very much
