how to open a file with iLogic and use iProp
Hello
Wath am I doing wrong. I want the code to open the file that meets the iProp.
But now I get the error message "open is not a member from string"
how can I slove this ? the red color is wrong
Thanks in advance.
' Get the active assembly document.
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
' Iterate through all of the documents referenced by the assembly.
Dim oDoc As Document
For Each oDoc In oAsmDoc.AllReferencedDocuments
' Verify that the document is a part.
If oDoc.DocumentType = kPartDocumentObject Then
Dim oPartDoc As PartDocument = oDoc
'Manipulate part
Dim model As String = oPartDoc.DisplayName
model = model & ".ipt"
If iProperties.Value(model,"Summary", "subject") = "muppet" Then
MessageBox.Show("je bent zelf een muppet " & model)
model.Open
Else
MessageBox.Show("Message", "Title")
Next
tnx
To open a document the file path of your file should be defined which was not done in your code. I've a modified code of your's which might be helpful.
'Manipulate part
Dim model As String = oPartDoc.FullFileName
ThisApplication.Documents.Open (model)
Else
Next
Dim model As String = oPartDoc.FullFileName Dim emodel As String = oPartDoc.DisplayName emodel = emodel & ".ipt" If iProperties.Value(emodel,"Summary", "subject") = "muppet" Then 'MessageBox.Show("je bent zelf een muppet " & model) Xdoc = ThisApplication.Documents.Open (model,False) Xdoc.rebuild
hello
The code did not work bur it helped me to slove the solution above
thanks for the help
