How to LoadAddIn/LoadPackageContents in Inventor?
ricaun
Advisor Advisor
ricaun
Hello I'm new in Invertor API and have a lot of experience with Revit API.
I wonder if there are some native method like LoadAddIn or LoadPackageContents inside Inventor API.
LoadAddIn(string fileName) : Loads add-ins from the given manifest file.
LoadPackageContents(packageContentsPath) : Loads add-ins from the given packageContents.xml file.
If someone know some similar method or way would be great.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
marcin_otręba
hi,
I am affraid there is not.
I use locator functionality instead:
Private loc As New Locator()
Dim currentPath As String = Path.GetDirectoryName(Reflection.Assembly.GetExecutingAssembly().Location) & "\Lib"
loc.InstallLocator(currentPath)
  Public Class Locator
        Private _path As String
        Public Sub New()
        End Sub
        Public Sub InstallLocator(ByVal path As String)
            _path = path
            AddHandler AppDomain.CurrentDomain.AssemblyResolve, AddressOf AssemblyResolve
        End Sub
        Private Function AssemblyResolve(ByVal sender As Object, ByVal args As ResolveEventArgs) As Assembly
            Dim position As Integer = args.Name.IndexOf(",")
            If position > -1 Then
                Try
                    Dim assemblyName As String = args.Name.Substring(0, position)
                    Dim assemblyFullPath As String = String.Empty
                    'look in main folder
                    assemblyFullPath = _path & "\" & assemblyName & ".dll"
                    If File.Exists(assemblyFullPath) Then
                        Return Assembly.LoadFrom(assemblyFullPath)
                Catch ex As Exception
                    System.Diagnostics.Debug.WriteLine(ex.Message)
                End Try
            Return Nothing
        End Function
    End Class
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
ricaun
I kinda need something more native to make the application inside the ApplicationAddIns list and show in the Add-In Manager Reference.
To find the Guid class and create an instance is not hard to make:
using Inventor;
using System;
using System.Runtime.InteropServices;
using System.Reflection;
public static class InventorAddinLoader
    public static ApplicationAddInServer CreateApplication(Assembly assembly, Guid guid)
        var exportedTypes = assembly.GetExportedTypes();
        foreach (var type in exportedTypes)
            if (type.GetInterface(typeof(ApplicationAddInServer).FullName) == null)
                continue;
            if (type.GetCustomAttribute<GuidAttribute>() is GuidAttribute guidAttribute)
                if (new Guid(guidAttribute.Value) != guid)
                    continue;
                return assembly.CreateInstance(type.FullName) as ApplicationAddInServer;
        return default;
After looking in the Add-In Manager UI don't think is possible to load a addin when Inventor is open, only when startup.
