How to link ilogic in the part to the assembly?
I am facing some problem on ilogic in assembly.
First, I done my parts with their own ilogic rules. And the parts are assembled together.
When I change the parameter at the part, and press the "update" button in the assembly, the dimension will be change. However, this is not a efficient way as I am having 3 parts that need to customize the parameters.
Due to the customer requirement, I have to create some method to change my parameter of my parts inside my assembly file.
Is there any method to link my ilogic in parts to the assembly?
Thank you.
bretrick30
You can use this snippet to change a parameter value in a sub component.
SyntaxEditor Code Snippet
Parameter("PartName_InBrowser", "ParameterName") = 1.2
