How to link dimensions to a table using Ilogic
ashleyU6MWT
ashleyU6MWT
Hi, I am looking to add a table to my part drawings using ilogic, but I would like the rows in the table to be filled with some 'critical dimensions' which the manufacturer must check and fill in when machining the part. I will identify these dimensions by using either an underline on each one or possibly using the 'basic' dimension style etc (what i am saying is these will have a feature to identify them and this can be used to put these specific dimensions into my table). Is this possible? the headings of the table would be dimension and first off inspection check. Thank you!
GosponZ
Easiest is make sketch on part and dimension it with and length. Then go to parameters and those  dimension name as with and length. Place checkmark to export parameters. When insert table with same properties dimensions will be there.
