How to know the item number of surface bodies
SandmanINV
SandmanINV
Hi everyone,
I have a body, and i want to create hole on 1 surface like i click with blue hight light.
I wonder, how to know the item number of each surface bodies from 1 body like this or more complicated. Now, i have to try by hand, by change number from 1 to .... and run to see that is what i want or not.
Thank you,
philip1009
Are you using Inventor 2019?  If so, then you have the ability to right-click on a surface and Assign a Name to either a face, line, or vertex(point), then these names can be referred to in iLogic code snippets:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2019...
SandmanINV
Thank you for your reply,
Yes, I am using Inventor 2019.
In my case, i create this body automatic by vb code. And now i want auto create holes on surface which clicked as my picture.
So, i want to know the number of each surface  without click to assign name or try by hand. Dose it has any rule numbering surfaces of one body ?
philip1009
Gotcha, in that case, I'm not too familiar with the VB code for determining geometry.  If you know where the hole is supposed to go in relation to the origin, maybe make a work plane in place of the face and use that as a reference for the hole to start from, or there's a way to know the direction of the face from the appropriate origin plane and go from there.  I do know it's possible, I'm sure someone will come up with something clever for you.  Good luck.
SandmanINV
Thank you for your reply, i think using Workplanes to reference hole is good way.
I hope someone have another advice. Thank you.
