How to keep suppressed and unsuppressed parameters in multiples model states
thomasadson14
Message 1 of 1
thomasadson14
Hi there!
I'm having some troubles while working with multiples "model states" in inventor.
Here's the problem. First:  i have an iLogic form that allows me to change some dimensions of my principal assembly called "Cabine".
In that iLogic Form i have an option to choose wich brake i'll use, so i have "Freio 3,5t" and "Freio 4,5t". But both of them are fixed in the "same" base but the position of that base changes according to wich brake i'm choosing. So i have this rule:
Component.IsActive("CONJUNTO FREIO CREMALHEIRA - SLIM 4,5T:1") = FREIO_4500T
 Select Case FREIO_4500T
 Case True
	 Component.IsActive("CONJUNTO FREIO CREMALHEIRA - SLIM 4,5T:1") = True
	Constraint.IsActive("Mate:37") = False
	Constraint.IsActive("Mate:38") = False
	Constraint.IsActive("Mate:39") = False
	Constraint.IsActive("Mate:40") = False
	Constraint.IsActive("Mate:41") = False
	Constraint.IsActive("Mate:42") = False
	Constraint.IsActive("Flush:40") = False
	Constraint.IsActive("Flush:43") = False
	Constraint.IsActive("Flush:46") = True
	Constraint.IsActive("Mate:54") = True
	Constraint.IsActive("Mate:55") = True
	Constraint.IsActive("Mate:56") = True
	Constraint.IsActive("Mate:57") = True
	Constraint.IsActive("Flush:47") = True
	Parameter("MRS 5878_ELC225_P126:1", "Freios_1") = (Parameter("Sketch G Corpo Lateral:1", "Esp_Atuador") -(Dist_Freio_4T * -1) -350)
Parameter("MRS 5878_ELC225_P127:1", "Freios_2") = (Parameter("Sketch G Corpo Lateral:1", "Esp_Atuador") - Parameter("MRS 5878_ELC225_P126:1", "Freios_1") -620)
 Case False
	 Component.IsActive("CONJUNTO FREIO CREMALHEIRA - SLIM 4,5T:1") = False
	 	Constraint.IsActive("Mate:37") = True
	Constraint.IsActive("Mate:38") = True
	Constraint.IsActive("Mate:39") = True
	Constraint.IsActive("Mate:40") = True
	Constraint.IsActive("Mate:41") = True
	Constraint.IsActive("Mate:42") = True
	Constraint.IsActive("Flush:40") = True
	Constraint.IsActive("Flush:43") = True
	Constraint.IsActive("Flush:46") = False
	Constraint.IsActive("Mate:54") = False
	Constraint.IsActive("Mate:55") = False
	Constraint.IsActive("Mate:56") = False
	Constraint.IsActive("Mate:57") = False
	Constraint.IsActive("Flush:47") = False
	Parameter("MRS 5878_ELC225_P126:1", "Freios_1") = (Parameter("Sketch G Corpo Lateral:1", "Esp_Atuador") -(Dist_Freio_3T * -1) -305)
Parameter("MRS 5878_ELC225_P127:1", "Freios_2") = (Parameter("Sketch G Corpo Lateral:1", "Esp_Atuador") - Parameter("MRS 5878_ELC225_P126:1", "Freios_1") -530)
 End Select
 Component.IsActive("CONJUNTO FREIO CREMALHEIRA - SLIM:1") = FREIO_3500T
 Select Case FREIO_3500T
 Case True
	 Component.IsActive("CONJUNTO FREIO CREMALHEIRA - SLIM:1") = True
 Case False
	 Component.IsActive("CONJUNTO FREIO CREMALHEIRA - SLIM:1") = False
 End Select
If FREIO_3500T = True Then
	FREIO_4500T = False
	If FREIO_4500T = True Then
		FREIO_3500T = False
 Basicly if i choose "Freio 3,5t" all the constraints related to him are set as active, and those who are positioning the "Freio 4,5t" are suppressed. When i choose "Freio 4,5t" the same thing happens but activating constraints related to him.  And is working pretty well, no problems suppressing or un-supressing those constraints.
The problem is that in the "Primary" model state that rule is working, but when i switch to the model state called "Carcaca" those constraints that are suppressed or un-supressed dont reply in this model states. Another problem is that the values of parameters also don't reply in this different model states, like: the "Flush 43" in the Primary model state has a value of 300mm, if i change him for 450mm in primary model state, that change does not apply in the model state "Carcaca", it keep beeing 300mm.
How can i keep those suppressed constraints and the value of parameters to be the same in both model states?
Replies (0)
